Solid 350 Horsepower
Re: Solid 350 Horsepower
Postby diesel freak01 » Wed Sep 15, 2010 4:28 am
1993 d350 ctd drw 2wd auto
diesel freak01
Postby JQmile » Wed Sep 15, 2010 10:05 am
I hit 301 with intake, exhaust, a fuel pin, and ddp4 injectors through a 727 with a converter, so I think your goal sounds reasonable.
Edit: oh, that was also on a stock turbo with no i/c :D
JQmile
Postby rusty6b » Wed Sep 15, 2010 7:38 pm
JQmile wrote:I hit 301 with intake, exhaust, a fuel pin, and ddp4 injectors through a 727 with a converter, so I think your goal sounds reasonable.
Your doing the rust bucket recession build rite? Love it man I'm following it closely. Looking forward to the next issue.
rusty6b
Postby 91_CUMMINS » Fri Oct 08, 2010 9:26 pm
ahale2772 wrote:if u want to go electric think airdog, fass or aeromotive, if you want to go mechanical the second gen 30 psi pump works great with a bypass regulator
Where do I find a regulator for one of those 2nd gen pumps and how much are they? Hard to install?
91 RAM 350, 75HP POD's, HX44, 600HP southbend, ARP head studs, custom intake, 4"exhaust, 3"stainless coolertubz, maxed VE, fuel pin, 3200, snow performance stage 2, boost/pyro guages, 2" lift, 33's/16's, What next?
91_CUMMINS
Postby ahale2772 » Sat Oct 09, 2010 8:16 pm
its a malory reg from summit, not hard to hook up but i also had a bunch of fittings that i could bs it together with, therefore i didnt spend any money other than the reg
Postby freak007 » Sat Nov 20, 2010 5:49 pm
This combo made 353Hp and 747 Torque:
My truck is a '85 W350 Crew Cab, it is lifted 6" and has 315/75/16 tires with 3.54 gears. It is powered with a '92 CTD with the following mods:
  • ISSPRO Boost, fuel pressure, pyro gauges
  • South Bend Con O clutch
  • 5 x .014 injectors
  • HTT 62/65/13
  • Source Automotive (Diamond Eye) 4" turbo back, straight pipe exhaust
  • BHAF
  • Piston Lift pump, 3/8" feed line, 5/16" return
  • A1 studs with OEM gasket
  • 3200 RPM governor spring
  • Turned full fuel screw several (6?) turns (on the edge of runaway)
  • Timing advanced 3/8"
  • Starwheel is up 4 turns from bottom, pin is shallow side forward, smoke screw all the way out (When I did this the smoke was greatly reduced and spool-up was noticeably faster)
    KSB hotwired
With this setup I was hitting 40lbs of boost. With the KSB switch off I was ~325/725. I did not like the "rattle" that came with the timing bump, so I have since pulled the timing back to stock and added a M&H timing spacer, I have also added M&H M2 fuel pin. I am now running 48 lbs of boost... I have not been on the dyno again, but the "assometer" says I gained a significant amount of torque. Next week I am installing a ported/oringed head, I then will hit the rollers again, I am hoping to see 380hp and 850 torque.
'85 Crew Cab with '92 CTD running gear. Rebuilt Getrag, SBC ConO, A1 studs, 5x.014s, HTT 62/65/13, Diamond Eye straight pipe exhaust, BHAF, pump tuned, timing advanced 3/8", KSB hotwire = 353/747. Since added M2 fuel pin and timing spacer, PDI manifold, Ported/O-ringed head... 400 club here i come ;)
freak007
Postby KTA » Sat Nov 20, 2010 8:50 pm
There aren't many things that bother me, but hood stacks on street trucks is certainly one of them. They look dumb and worst of all are unsafe. Not only do you run the risk of running exhaust fumes into your cab, but they also get soot all over your windshield, even the fine stuff that you can't se gets on there, then at night you wonder why it is hard to see, so you turn your wipers on and hit the spray to wash them off. Now you have a nice oil slick on your windshield so everytime headlights hit it it looks like you are crashing into a rainbow and you can't see out! Do it right and do it safe and put a down pipe on it!!
Postby Douglas » Tue Nov 23, 2010 1:07 pm
rusty6b wrote:Thanks a lot guys thats all I can think of rite now. I'll use whatever lift pump option is cheapest. Currently trying to use my first gen's crossmember in my truck... If I can make it work it'll save me 400 bucks.
Is there a Coolertubz.com or do I have to contact TWorline personally?
hey-Hey!!!,
Consider one of the electrics that is OK with Diesel. I have the Carter 4601 in my 1990 and it is serving well. Install was simple( powered it with a relay tripped off the fuel shut-off on the IP). It is set for 16 psi, and well over the flow requirements of a motor much wilder than mine.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
