Short Bed Cummins
both inside and out
Short Bed Cummins
Postby Collers9640 » Tue Sep 07, 2010 3:56 pm
I need all the help i can get with my short bed conversion. I have a 2wd reg. cab. If anyone has photos, instructions, and what gas tank i can use or any other parts i will need for that matter will be greatly helpful.
Thanks Matt
Collers9640
Re: Short Bed Cummins
Postby dpuckett » Fri Sep 24, 2010 6:27 pm
You should be able to reuse your current fuel tank, if your frame is not being modified. The spout will flex quite a bit.
Cant help ya on the frame- it may or may not be the same with a reg cab/long bed vs a xcab/ short bed.
DP
Postby TELEMETAL » Tue Nov 09, 2010 8:44 pm
Heres what I did. Tank is from a 1980 something Ford Econoline van.
TELEMETAL
smoke screw?
Postby RumbleFish » Wed Nov 10, 2010 12:11 pm
dpuckett wrote: it may or may not be the same with a reg cab/long bed vs a xcab/ short bed.
they are not the same.
Return to Body
