16cm exahaust housing
Postby Power Ram Man » Sun Jul 22, 2007 1:32 pm
i was wondering if a 16cm exhaust housing was good to pull with, my friend who is a mechanic tells me not to do it because i would not be getting enough air out the exhaust side and will evenually burn a piston i realy dont know what is the right size for towing and for more boost which i despratly need only getting 19 psi right now
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
Postby PToombs » Sun Jul 22, 2007 3:57 pm
I bet he works on ferds, right? :lol: Put the 16 on and don't look back! I put one on mine and haven't had a problem. I was towing about 11k last week, and I'm running a lot of fuel. On the level I was running 1000* to 1100*. On the hills, 1200* to 1250*.
Postby Power Ram Man » Sun Jul 22, 2007 7:37 pm
hw works on alot of tractors and gassers and a few powerstrokes see he thinks my motors going to blow because of all the problems ford had with the small housing i keep trying to tell him that a powerjoke is a total different motor but insists that a diesel is a diesel hes what do you call hard headed
Power Ram Man
Postby gman07 » Sun Jul 22, 2007 8:20 pm
As long as you're keeping a good eye on the pyrometer, it'll be fine. The 16cm is a good all-around housing; "choking" the exhaust isn't much of an issue unless you're running a 12cm housing or an HY35.
gman07
Postby MikeThomas » Sun Jul 22, 2007 11:38 pm
There is no way a 16 will starve you for air...I have 3.5 turns of the naughty screw, ground pin, and a stage 4 turbo upgrade on a 16cm and finally hit 1100...I had to dog the bajesus out of it up a hill to get that. :P
1993 W250, 5SPD, ne370's, HTT STAGE IV/14wg, DennT Pin, BHAF, P-PUMP, PUMP TWEEKS, 4" EXHAUST, 366
MikeThomas
Postby Falcon » Mon Jul 23, 2007 2:23 pm
16 is fine I got one on my hx-35 no problem with it at all.
Greg
Greg
Graham, Washington
"FIRST REAL TRUCK ENGINE...
LAST REAL TRUCK!!!
93 ex cab 4x4, Hybred 35/40,4" exaust all the way,pump turned alittle,DDP Stage III's, 366 spring,DDP fuel pin,AFE first gen air intake,pyro and boost gauges
Falcon
16 cm towing
Postby charger 69 » Mon Jul 23, 2007 7:12 pm
I have a 16cm and pull about 10-12K when I do it and the 16 cut the black cloud in half starting up with a load. I also have 3.5 turns on the fuel screw which puts the boost at 28 lb under load. Climbing a hill I have to watch the hot meter but that isn't because of the housing,it was a great improvment for mine.
92 White D350 132K,mi. fuel screw in 3,5 turns automatic with a Hughes converter and 26K add on cooler.Aluminum wheels,second fuel tank,gooseneck hitch,air bags tach.and gages,
charger 69
Postby ez_lle71 » Tue Aug 07, 2007 9:58 pm
I just put a hx-35 on my 92'. Has the 12cm2 wastegated housing and ive had no problems.
92'D250,5spd,5"turnoutstack,BHAF&intake,isspropyro&boost,2turns full fuel screw,2turns smoke screw,fuel pin set deep,hx-35, 2nd gen chrome rims
ez_lle71
Postby Ace » Wed Aug 08, 2007 12:12 am
I never saw more than 1100 on the pyro with my 16 and the pump cranked all the way even before installing a Powerstroke IC. But evidently the stock IC injectors won't flow enough fuel to roast a marshmallow, much less burn a piston, so YMMV.
Postby Power Ram Man » Thu Aug 09, 2007 5:17 pm
just got my housing in through the mail through high tech turbo for 155$
hopefully im going to get it in this saturday
Power Ram Man
Postby TWorline » Thu Aug 09, 2007 5:50 pm
It would be a good ideal to start soaking the turbo nuts with PB Blaster now, it works real good to spray them when you park it while it is still warm.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby Power Ram Man » Thu Oct 11, 2007 5:28 am
Got it on wow the difference is great im running around 800 degrees and the most i got is 1100 but im still only getting 24 pounds of boost maximum with 2 screws on the naughty screw and other pump mods next im planning on putting on a 3200 govener spring
Power Ram Man
Postby moab4x4 » Sun Oct 14, 2007 2:28 am
You will love that 366 spring as much as the 16 cm housing. :)
I can get mine too hot by dropping the hammer at too low RPMs. Once I am at 2k though I have enough air to burn all that fuel.
92 W350 LE Getrag, 3.54, 4"/2" lift,
HTT Stage II, POD's, 4", PDR cam, KDP, 3200 GSK, Pin ground, Keyed Valet
Pyro, Boost in Message Center, Isspro tach, Damplifier-ed entire cab! Dual Batts, Keyless Entry, LED's in dash
moab4x4
