Aftermarket intake manifold
Postby Cummins Jr. » Sat Oct 30, 2010 10:41 pm
I am wondering if we can fit aftermarket intake manifolds such as the AFE bladerunner or BANKS ram air,on our truck. Or even a 2nd or 3rd or 4th gen one on and how much better it would be for our motors, thanks :D
Cummins Jr.
smoke screw?
Re: Aftermarket intake manifold
Postby zach kinney » Sun Oct 31, 2010 8:30 am
i have tims coolertubz and i like it and i think a second gen one would also work on our trucks.
1990 dodge w250 non i/c 727, shift kit and deeper tranny pan, custom cold air, denny t fuel pin, star wheel turned down, fuel screw 2 turns, 5in stacks, 3200 spring, timming advanced 1/8", gauges, coolertubz, valet switch .
zach kinney
Postby IowaCummins » Sun Oct 31, 2010 9:12 am
i think the only ones that were worth putting on is the 24 valve horn or any aftermarket pieces. for a 1st gen i would deffly lookinto Tim worline for some cooler tubz. 3" stainless pollished beautiful pieces! i have some and love them. many guys have them on here with great results
IowaCummins
Postby PRINCETON_JAKE » Sun Oct 31, 2010 11:54 am
I have a stock 2nd gen intake and homeade 3" inner cooler tube on mine.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby 1STGENFARMBOY » Sun Oct 31, 2010 7:04 pm
Here is Tims tubes, they are a high quality part for shure.
Postby ellis93 » Sun Oct 31, 2010 8:00 pm
:mrgreen: I can hardly wait to get mine.
Postby unixcowboy » Sat Nov 06, 2010 1:35 pm
Got mine at S.O.P. #7 in Oct....
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
unixcowboy
Postby fatty » Sat Nov 06, 2010 4:14 pm
1STGENFARMBOY wrote:Here is Tims tubes, they are a high quality part for shure.
:shock: Your engine bay is almost as nice and clean as BC847!!
