im currently seeing around 48psi with the w/g hose pinched (
would it be much of an upgrade to run a hx40? my main concern would be spool up with the manual. i know the the 351 is on borrowed time being spun that fast, and drive pressure has to be thru the roof with the 9cm housing.
thanks
