dyno numbers
Re: dyno numbers
Postby KTA » Mon May 03, 2010 7:31 pm
No what I need to get me off my butt is an extra $2000 for an engine build for a toy. Sadly I don't have that laying around, and there are several other projects demanding my attention 1st like a cummins swap into my crew cab.
Re: dyno numbers
Postby RSWORDS » Tue May 04, 2010 2:23 pm
KTA wrote:No what I need to get me off my butt is an extra $2000 for an engine build for a toy. Sadly I don't have that laying around, and there are several other projects demanding my attention 1st like a cummins swap into my crew cab.
I hear you all the way around on that!
RSWORDS
Re: dyno numbers
Postby oldestof11 » Tue May 04, 2010 5:02 pm
I have a "extra" 12v VE and a extra VE, and a 727 all apart, and a 87 Suburban....
LOL!
Gonna mill off the log and build a intake manifold, P&P, possibly bigger valves, etc. Just need to get off my butt and work.
Re: dyno numbers
Postby Tacoclaw » Sun Jun 06, 2010 7:13 pm
My pile managed to wheeze out 268 horse on the dyno. No optical pickup, so no torque numbers. I may be able to squeeze out a bit more next time.
Hineman decided to show me a trick with my throttle linkage, so it goes a bit further now.
No more throttle linkage getting in the way, that's what coat hangers are for. :lol:
Re: dyno numbers
Postby AHineman » Sun Jun 06, 2010 8:07 pm
Now Levi, that was supposed to be a proprietary modification. :lol:
I should have known better than mess with a 20 year old part that is infamous for breaking when we're 2 hours from home. Thankfully we had a Leatherman and a coat hanger. The old beast sounded pretty good. Maybe next time we can make it through the weekend without a tornado and severe thunderstorms. :evil:
Re: dyno numbers
Postby Tacoclaw » Mon Jun 07, 2010 8:23 am
For anyone looking for a baseline, my truck has a LP piston pump, fuel screw about 3/4 from runaway, 62/65/12 S300, homemade 4 inch exhaust, BHAF, 3 inch crossover with non-functional(as of right now)air-to-water IC, and a Getrag swap.
By the way Hineman, I need you to iron all my shirts until I get another throttle linkage sorted out. :P
Re: dyno numbers
Postby JBradley500 » Sat Aug 28, 2010 3:20 pm
Schieds Mustang... Low numbers were with the KSB Hotwire switch on... It sounded flat up top with power to the ksb.
340hp/662tq (8/24/12)
JBradley500
Re: dyno numbers
Postby 93flatbed » Mon Sep 13, 2010 8:25 pm
I did 339 and 708 on 9/11/10. In 4th gear! I was told there was no correction but now there is a roumor there was a 3-4% correction? I'm not sure, but I'm happy I broke 300!
93flatbed
Re: dyno numbers
Postby BC847 » Mon Oct 18, 2010 4:15 pm
Made a dyno-run today. (12mm VE IP, #2 Fuel only, No correction factor)
EDIT: And no AFC fuel enrichment. The daggum boost reference tube had blown off earlier and I failed to see it when I failed to check thoroughly days earlier. My name is David, and I'm a putz..
It's been 11 months since I ran that dyno (DynoJet 248C) last. I've changed the HX35/40 hybrid secondary to an S362/14, tightened the NON lock-up converter a little, and swapped the Cummins 60# valvesprings for some Hamilton stuff since. Got a big boost in torque at the expense of a little horsepower (I guess) and now have the power band available at a lower engine RPM range (shifted to the left).
This dyno run (Blue) compared to the last (Green) . . .
Re: dyno numbers
Postby 1STGENFARMBOY » Mon Oct 18, 2010 8:31 pm
Do you think the converter had much to do with that big torque number? I would gladly give up
that little amount of HP for that huge gain in torque.
Dar
Re: dyno numbers
Postby BC847 » Tue Oct 19, 2010 10:51 am
1STGENFARMBOY wrote:Do you think the converter had much to do with that big torque number? I would gladly give up
Dar,
I think the converter tightening was what moved to power to the left. The better flowing hot-side of the S300 (compared to the HX35) is responsible for the torque gain. :)
Re: dyno numbers
Postby lopez dodge » Wed Nov 03, 2010 11:11 am
funny the truck always seems to runout better on the street than on the rollers . but for it being only my second time on I am pretty happy with the results. 375hp 697 tq. :!:
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
Re: dyno numbers
Postby motorwood » Tue Nov 16, 2010 7:05 pm
379hp 848tq pods, H1C/E 21cm, stock lift pump, 354 spring, 1/4"timing advance,KSB energized :D
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Re: dyno numbers
Postby 1990 » Fri Nov 19, 2010 7:00 pm
motorwood wrote:379hp 848tq pods, H1C/E 21cm, stock lift pump, 354 spring, 1/4"timing advance,KSB energized :D
I don't believe that.
2012 Subaru WRX TP Stage 1 DD
Re: dyno numbers
Postby motorwood » Fri Nov 19, 2010 8:36 pm
We made three runs, one with 1/8th" timing and no KSB (331hp 805tq) then two more with 1/4timing" and KSB energized (379hp 848tq, 374hp 832tq) The shop is reputable and had nothing to gain by inflating the numbers since I did my own engine work. I cant get my sheets to upload for some reason. I will as soon as I can I will. I'm gonna drag race it tomorrow, dont have high hopes trying to shift a manual truck transmission.
motorwood
Return to Competition
