90 style grill on a 93??
both inside and out
Postby rattlebox93 » Thu Nov 25, 2010 1:48 pm
i was wanting to put the 90 style grill and old style "bird bath" hood on my 93 will that be a big undertaking or a fairly easy project? thans a ton in advance dj
rattlebox93
Re: 90 style grill on a 93??
Postby delinquent » Thu Nov 25, 2010 1:53 pm
Not 100% sure but I think the core support is different
delinquent
Postby rattlebox93 » Thu Nov 25, 2010 3:09 pm
huh? lol
rattlebox93
Postby IowaCummins » Thu Nov 25, 2010 5:16 pm
the 93 has a intercooler, half way through 91 they put those in, to fit them they had to change the radiator support, which is the grille support/ radiator support. so unless someone has gotten an old grille to fit with a intercooler off a 1st gen i think it would be easiest to get a non intercooled grille support and do a 2nd gen intercooler conversion.
IowaCummins
Postby PToombs » Thu Nov 25, 2010 5:25 pm
You need to change the valance by the windshield if you change the hood.
Postby rattlebox93 » Fri Nov 26, 2010 7:20 am
dam looks like i will be doin the hood and not the grill im not goin through all that trouble for the grill
rattlebox93
Postby IowaCummins » Fri Nov 26, 2010 4:02 pm
yeah it would be a lot of work just for the look. if it was easy i know i would definitely have a 78 grille on my truck cause i love those marker lights on that year.
IowaCummins
Postby Remps » Sat Nov 27, 2010 9:45 am
Will the hood latch from a 93 bolt up to a bird bath hood, or would it require some modification? What about the hinges? My '74 's hood opens with an external latch..
Postby Mark Nixon » Mon Nov 29, 2010 5:32 pm
If you use the birbath hood with any core support after 1980, the hood latch loop needs to be moved over @ 3/4" to the passenger's side.
You also SHOULD put nuts on the backside of the loop, in the hood understructure, as the new location isn't reinforced properly for the loop and is single tin thickness, so the bolts will pull out.
The safety catch location is, I believe, the same clear though to 1993 (Dangit, I have to go look now!).
As mentiond, you will need the cowl/wiper screen.
You also should change the wiper pivots, as the later pivots are taller, but the later ones just sit higher.
If you're doing it with an INTERCOOLED radiator, the radiator cap and both shroud tabs will hit in the section of understructure directly above the radiator, I just scalloped out the structure at all 3 points.
Here's the "Birdy" hood and cowl screen installed on my old Carhauler:
Postby Fastback66 » Tue Nov 30, 2010 7:37 pm
IowaCummins wrote:yeah it would be a lot of work just for the look. if it was easy i know i would definitely have a 78 grille on my truck cause i love those marker lights on that year.
It's really not that hard of a job. Did most of it in an evening. I used a 1979 quad headlight but still the same job. Little drilling of spot welds and some grinding/ welding.
Vinny
78 D-200 Crew cab LWB converted to 4wd then converted to Diesel. 366 spring, custom pin, timing to head and pump tweaked.
75 W-100 SWB step side under construction. Soon to be 318 magnum/518 auto.
66 Charger 383/auto
71 Chrysler Newport hardtop 4dr. 360/727. Need drivers side body panels if ya got some.
Fastback66
Postby dannyd » Fri Dec 03, 2010 12:40 pm
i have put the birdbath hood on my 89 ramcharger you do have to change the wipper cowl and use the latch for the birdbath hood heres some pictures of the hood and latch Image Image Image
dannyd
smoke screw?
Return to Body
