PRINCETON_JAKE wrote:I put a 12cm housing on mine and loved it, I also have other mods, the thing i liked was it eliminated turbo lag.
Subliminal wrote:I swapped from a 21cm to a 12cm with the wastegate welded shut.
It's a little bit longer, so you have to work a little harder to get it on (I think I just had to pull the bolt to the transmission and then rebolt it up later).
That being said, it definitely spools a LOT faster. I used to get almost no boost until the top 1/2 of 3rd gear, now I can get a little boost in neutral...lol.
My EGTs didn't really go up at all. I don't tow heavy, but 80 MPH with 5k behind me was under 1k on the pyro.
I'd say do it...nice $50 upgrade.
oldestof11 wrote:It is my belief, that unless you are towing heavy, a 12 cm not only helps spool-up but also EGT's on a slightly modded truck. Reason being, it gets the turbo into its efficiency map quicker and with less fuel.
delinquent wrote:If anyone needs a 12cm housing, I've got a couple I'd like to part with!
ktekst wrote:delinquent wrote:If anyone needs a 12cm housing, I've got a couple I'd like to part with!
And are they the short outlet?.... Somewhere I remember reading that there are short and long outlets and the long one moves the exhaust back possibly causing clearance issues.
Douglas wrote:I think there are three 'lengths' available, one stock WG housing with a 3' clamp on the WG cover, a non-WG'd housing that is the same length as the WG'd one with a V-band clamp, and a short non-WG'd that is the same length as any other of the OE non-WG'd housings.
cheers,
Douglas
