Body Swap Questions!!
both inside and out
Postby sb91ctd » Thu Dec 23, 2010 1:37 am
Hey guys i know this has probably been asked quite a few times but ive got a few concerns about a body swap from an 85 d150 gasser to my 91 w250 (body is junk obviously). Ive been hearing about the center hump not being able to clear the tranny, will/should all body and bed mounts match up, and my worst fear....the electrical aspect of the swap :shock: . Both trucks are standard cab long bed and both are auto. Even though i havent bought the 85 just yet the chance is pretty decent i will. Any help would be greatly appreciated here.
Thanks guys,
Steve
Steve
1991 W250, stock for the moment, 146,xxx , 727 with transgo shift kit, non i/c, currently being assymbled
1988 super10 4cyl 5sp
sb91ctd
Re: Body Swap Questions!!
Postby Remps » Thu Dec 23, 2010 4:37 am
I'm 99% sure that the body will bolt right on. If your diesel is intercooled, you'll want to swap the rad support from the 91 to the 85. I'm sure someone who has done the swap will give you electrical details and what not..
Postby RumbleFish » Thu Dec 23, 2010 7:26 am
pete swapped a 87ish gasser cab onto his 92. im sure he has some useful info to add along with alot of other not so useful chatter.
Postby BobS » Thu Dec 23, 2010 8:41 am
All the body mounts are in the same locations for the cab way back to the 70's and possibly even earlier. You have to match the center humps for the transmission & transfer case body clearance. This could require cutting and grafting or bolting in the old center hump to the gasser cab. If you cut it properly you can make it removable just like the earlier versions that dodge used before they went into their cost cutting mode.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby PToombs » Thu Dec 23, 2010 7:02 pm
Bob covered it. I had to cut the hump and put it in the '86 cab. If you have 4x4 or a stick, you get the big hump, 2wd auto, you get the small one. I also had to cut the firewall because I have a stick, the clutch master goes thru where the electrical bulkhead comes thru on the '86. No worries for you though. Cut the hump large on the old cab and the hole small on the new one, then trim both until you get a good fit. It took me about 3 hours to cut the new cab and fit the hump in.
Just pull the harness from the '91 and put it in the other cab. It's not that bad of a job, I was dreading it until I did it, piece of cake!
Postby sb91ctd » Thu Dec 23, 2010 11:12 pm
Ok thanks guys, and no it not intercooled, unfortunatly the fun wont begin until spring or so due to this lovely cold weather and the fact ill pretty much be doing this outside lol.
Steve
sb91ctd
Return to Body
