overdrive... etc
overdrive... etc
Postby I<3Twins » Tue Jan 18, 2011 9:18 pm
so my overdrive, speedo, odo, wait to start light, and a couple other things decided to stop working one day, all athe same time. i looked in the owners manual and saw that all of the things that weren't working were all on the same fuse. i changed the fuse and checked both sides of it to see that it was hot. i also had the brain box rebuilt, and got a new speedo sensor. i also switched the tps with another one that a friend had to see if that would fix it.
all i really want is my speedo and overdrive back. is this a common problem with these? and does anyone know what the problem could be?
any info would be greatly appreciated
91.5 W250 auto
#366, ground pin, pump tweaked, starwheel bottomed, piston lp, muffler is MIA, 6in tip
I<3Twins
smoke screw?
Re: overdrive... etc
Postby ellis93 » Wed Jan 19, 2011 4:46 am
Ignition switch might be bad. May not be turning on the computer.
Postby Mark Nixon » Wed Jan 19, 2011 4:31 pm
When those items don't work, it's USUALLY one of the fusible links near the hood hinge.
Postby I<3Twins » Thu Jan 20, 2011 9:27 pm
thanks guys, i'll check into those things here within the week if not tomorrow :-D
91.5 W250 auto
I<3Twins
smoke screw?
Return to Electrical
