ahale2772 wrote:(Looking for a s300 64/71/14) Can I even get a turbo that specific from a place that sells basic stock turbos?
Thanks
AHineman wrote:I got my stuff at Turbosupply.net. If you look through borg warner's catalog (google airwerks), you can find the part numbers. If you wanted to run an external gate, you can get the stock s300's for fairly cheap. I just don't know if you can get the correct AR ratio to spool the t4 housing. Fitting a down pipe would suck also. Just get an s300g and an s475 and build twins.Also sorry for no links, using my phone.
AHineman wrote:Spools real well IMHO. Max egt so far of 1250*, but the exhaust side of my head is ported and my exhaust manifold is also ported. I put a turbuckle on my wastegate actuator so mine is now adjustable...got it from BD for about $60. I have it set at 25 psi right now but haven't had time for tuning.
Richie O wrote: I can hit 1400 with my 89 with 3/16'ths advance timing right at 300 horses. ( well 3hp under 300 )Thats at 34 psi with the gate unhooked. Powerstroke cooler, tube style cooler pipes, 4 inch exhaust.
AHineman wrote:You can get non gated 64/71 turbos stock
