steering wheel locked
both inside and out
Postby dodge1stgen » Fri Feb 04, 2011 6:54 pm
I bought a parts truck with no key,the wheels are half turned.How do I remove/break the steering lock so the wheel will turn.Thanks Eric
93 250 ext cab p pump injectors 2 disk clutch 3'' charger nv 4500 retired
92 350 ext cab 5 spd 366 spring bd injectors hx 35 dana 80 flatbed
92 350 converter built trans bd fuel pin flatbed/dumpbed
dodge1stgen
Re: steering wheel locked
Postby Mark Nixon » Fri Feb 04, 2011 8:44 pm
To do it "right", you'll need tamper proof Torx bits.
Pull the upper column covers (Also Torx screws) to reveal the ignition switch assembly, which is held in with 3 tamper-proof torx screws.
If the column is a tilting one, unscrew the tilt lever before you remove the upper covers.
Another way would be to unbolt the rag joint from the column.
Return to Body
