dcrossnrinfinet wrote:I just finished doing my wheel bearings on a 1991 w350. Here is a link which was very helpful for me.
http://www.dieseltruckresource.com/dev/ ... l?t=143024
I cannot describe everything from memory but can probably answer questions. You will need the tool to get the bearing lock nut off I believe this one is correct http://www.amazon.com/gp/product/B000K1 ... EMWPNMJ9N3. This is not the one I used. I went to Napa and picked one up but it was quite a bit more expensive. I believe you can also do a loaner tool program from Advance or Autozone to get the tool.
little doug wrote:The hub and rotor are two large pieces and 8 little pieces.![]()
The studs are pressed in ,holding the rotor to the hub.
slow_90firebird wrote:How bad are your rotors? You can usually re use them, unless there is a really big lip on the outside edge.
