Tacoclaw wrote:Just wondering, but when you have no cone in the bore and you hit the throttle, pushing it out does that simulate the maximum pin travel?
If so, it doesn't really look like it goes much more than halfway across the bore.
Halfagagga wrote:Can you confirm the pressures created by each fuel moving device inside the pump?
KTA wrote:I don't understand what you are asking????
dazedandconfused wrote:You have anyideas on how to dual feed the pump you would mind sharing?
