Last truck now has gauges
Postby Richie O » Wed Feb 23, 2011 3:05 pm
I have a couple more to get for the 89, but atleast all 3 have some of the needed gauges. This is in the 92 ( stockish ) truck.
So far wide open with load is 15 psi and 1100 degrees. This truck sure is a turd. 21mc housing and all. :D
Re: Last truck now has gauges
Postby Tacoclaw » Wed Feb 23, 2011 3:09 pm
You better get some studs on that thing ASAP. :lol:
Postby Richie O » Wed Feb 23, 2011 3:23 pm
I know, she is a ball of fire. :lol: I'm not going for power in this one. I need it to tow heavy 18 to sometimes 24,000 gross so it will remain mild. Right now I can just hold it all day long and not worry about anything.
Postby PToombs » Wed Feb 23, 2011 6:52 pm
Nice low profile wiring job. Matches that red interior perfect! :lol:
Postby Richie O » Wed Feb 23, 2011 6:53 pm
I just won't drill a dashboard. I know the wires look crappy, but I like it better then a bunch of holes.
Postby ellis93 » Wed Feb 23, 2011 9:52 pm
Mine had holes in it already :( So I covered it up with the three gauge pod from genos. Looks good mr richie.
Postby PToombs » Thu Feb 24, 2011 6:58 pm
But you drilled holes to mount the gauges! You're a hypocrite! :shock: Oh alright, I saw the 2 sided tape! :P
It looks good, Rich knows I'm busting his chops. ;) Here's another option for running wires, route them straight toward the defroster vent and slide them down the edge between the dash top and vent. IIRC, there's enough room to slide them thru there.
Postby Richie O » Thu Feb 24, 2011 7:07 pm
When I swap this dash into the new cab I may do somthing different. I did it this way knowing that in a year or so it all has to come back out to swap over. And Yes, Pete has permission to slap back. God knows I hit him enough. :D
Postby PToombs » Thu Feb 24, 2011 7:11 pm
Ya know, 1 ear is bigger than the other now. Can you use the other hand for a while? ;)
Postby ahale2772 » Thu Feb 24, 2011 8:14 pm
All your trucks have guages now? sounds like a great excuse to get another truck ... :D
Postby Richie O » Thu Feb 24, 2011 10:04 pm
ahale2772 wrote:All your trucks have guages now? sounds like a great excuse to get another truck ... :D
DON'T PUT IDEAS IN MY HEAD. 8)
Postby MMeier » Fri Feb 25, 2011 1:37 pm
60 # boost gauge on a 21 sq stocker !!! :roll: :lol: :evil:
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby Richie O » Fri Feb 25, 2011 1:44 pm
MMeier wrote:60 # boost gauge on a 21 sq stocker !!! :roll: :lol: :evil:
Who knows what the future might bring?? 30 psi gauges are a wast of money. My other trucks have 35 and 45 psi of boost, so some day this one might as well. :D
Postby manyholes » Sat Feb 26, 2011 2:21 pm
did you mount the gauges in your other trucks the same way?? ( top side of dash) or ??? i havent put gauges in mine yet, i have them in the garage, just need a pyro lead. i took them outta my 97 6.5, i had a pillar pod on that one, but i just dont think my pillar pod will work :lol: :roll:
just kinda hunting for ideas, i like the loom to hide the wiring
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Postby Richie O » Sat Feb 26, 2011 2:55 pm
manyholes wrote:did you mount the gauges in your other trucks the same way?? ( top side of dash) or ??? i havent put gauges in mine yet, i have them in the garage, just need a pyro lead. i took them outta my 97 6.5, i had a pillar pod on that one, but i just dont think my pillar pod will work :lol: :roll:
My 89,
My 93 home made nightmare, :D
