Broke fuel screw/is my inj. shop dumb?
Postby TWorline » Tue Aug 21, 2007 8:19 pm
Good to hear that you got it back on the road! Are you going to make it to Schieds? If so I can bring my wrench.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby RumbleFish » Tue Aug 21, 2007 8:51 pm
Nah, don't think I'm gonna make it this time. Thanks for the offer though. If I need it before I get mine I'll let you know.
Postby PToombs » Wed Aug 22, 2007 4:06 pm
On the tophat thing? That's why I said to hook it up, then slide the throttle shaft thru. :wink: I been there, done that! I found my washer on the crossmember under the engine, and the pin on the ground. :shock:
Next time, I'll push the shaft thru!
Glad you got 'er going again!
Postby Greenleaf » Fri Sep 07, 2007 9:16 am
Pete showed me the spring first/shaft second method at last SOP. It worked well. I simply never tried it. Never had reason to untill then. I couldn't get the gov spring to "bite and hook" but then, I have never had six guys watching my every move either. :shock: :oops: :(
Since then, I have had gov springs hook the first time, when I'm alone that is.
Thanks Pete.
Greenleaf
tech specialist/mod
the hard way
Postby seeker1056 » Fri Sep 07, 2007 12:50 pm
sounds awfully like the hard weay to me ;o)
its easier to push the top hat back thru the slot in the arm n just lift the whole thing out, sub the spring, and slide back down the slot - no muss no fuss
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby PToombs » Fri Sep 07, 2007 4:40 pm
You're welcome Scott. Nice sig, by the way! :lol:
