3800 gsk
3800 gsk
Postby skilletky » Fri Mar 18, 2011 8:32 pm
has anyone on here ever run one or currently use one? been thinking about getting one, but was doing some research and read that the 4200 or 3800 spring is longer than the 366 and can cause the gov to stick at higher rpms.
skilletky
Re: 3800 gsk
Postby Richie O » Fri Mar 18, 2011 8:35 pm
They need to be trimmed to the correct length. Pulltilbroke runs a 4200 and he trimmed it. He could tell you better then me.
Re: 3800 gsk
Postby skilletky » Fri Mar 18, 2011 9:12 pm
thanks richie, i just read a few threads below about the 4200 needing trimmed, but didnt see anything about the 3800. think i might just buy one and check it out. its only 30 bucks.
skilletky
Re: 3800 gsk
Postby skilletky » Fri Mar 18, 2011 9:36 pm
was also thinking of getting a new set of injectors, right now i got a tired set of new era 370's. was wanting to get something with a little extra umph. is it worth getting the ddp stg 4's. would pod's make more or less power than my current injectors?
skilletky
Re: 3800 gsk
Postby ciamcoop » Sat Mar 19, 2011 3:19 am
Is it really worth spinning it close to 4000 without major pump mods? Anyone have a dyno sheet showing that it'll keep pulling that high? I know mine isn't really done up much but I can feel the power plane out by 3000.
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Re: 3800 gsk
Postby SNOOT » Sat Mar 19, 2011 8:16 am
I run a 4200 spring with a good valve spring system. I dont use it for the HP factor but for the top speed fun in OD.. I did not trim my spring just indexed it so it worked.
1993 W350
SNOOT
Re: 3800 gsk
Postby skilletky » Sat Mar 19, 2011 2:37 pm
thats what i am looking for, a little more top speed. it does good now' but it figure a few more rpms can be better.
skilletky
Re: 3800 gsk
Postby skilletky » Mon Mar 21, 2011 7:17 am
do i need heavier valve springs with the 3800 gsk?
skilletky
Re: 3800 gsk
Postby PToombs » Mon Mar 21, 2011 5:03 pm
Ah yup. ;)
Well, if you plan on running it up there on a regular basis, and/ or holding it up there.
