Mystery injectors
Mystery injectors
Postby cougar » Mon Feb 21, 2011 12:13 pm
I pulled out my old injectors thinking about having them redone.
What I got;
on the body:
8965
KDAL 59 P 9 161 245bar
BOSCH 937 (in a circle) Bosch (emblem) FRANCE
nozzle is 5 hole
9745
The 245bar is right, but should be a 6 hole for a 91.5 intercooled. Another mystery from the previous owner. Anyone know what these are?
01 2500 "the work truck".
cougar
Re: Mystery injectors
Postby thumpertrev » Mon Feb 28, 2011 6:39 pm
Probably 5x.010. Those numbers seem familiar to me and when I figured mine out, that's what they were. These where in my 92 engine.
1994 Ford crew cab dually.Turbos-WH1C over a TV8102,3" charge piping,largest aluminum I/C I could fit,5" turbo back,SDX11 5x12,mild head porting,ARP studs,Throttle mod,ground pin,366 spring, fuel screw bottomed(no runaway),A518 with low stall converter.
thumpertrev
Postby cougar » Fri Apr 01, 2011 2:54 pm
Finally got my gauge pins and measured the holes. They are 5X.012". That might make them 2nd gen 370 nozzles. They sure didn't run like it. The +40hp that replaced them run stronger.
cougar
Postby Remps » Sun Apr 03, 2011 12:29 pm
Do you happen to have the numbers off of the +40's? And are they 5 hole? Still trying to figure out what my 4 hole "+40's" are. :/
Postby cougar » Sun Apr 03, 2011 1:14 pm
Yes, they are Bosch 0432131837.
As far as number of holes and size? I don't know. I wasn't thinking along those lines 2 years ago. Sorry.
They were worth the price and work well for me. Just trying to decide on what to do with the old ones.
cougar
Postby Smokem1 » Sat Apr 09, 2011 2:47 pm
The nozzle on that holder should be 155° 4x0.013" cylindrical sac type with an emission style needle.
Smokem1
Postby oldestof11 » Sat Apr 09, 2011 2:52 pm
Remps wrote:Do you happen to have the numbers off of the +40's? And are they 5 hole? Still trying to figure out what my 4 hole "+40's" are. :/
If they are a 4 holer, then the most likely injector is POD's.
Now, OP, if they were really 2nd Gen injectors and you got 40hp one made for a 1st Gen, then I could see an "increase" in power. Wonder what the pop off pressure was on the ones you pulled...
Postby Smokem1 » Sat Apr 09, 2011 2:57 pm
They are not a POD's, they are the same thing DDP sells as their 50hp injectors.
Tough to say on the original injector, but I would assume they are the 5x0.010" mini sac nozzle 145° cone angle.
Smokem1
Postby Remps » Sun Apr 10, 2011 6:54 am
Thanks Smokem, I think you're right. That would explain why they smoke more at WOT than 6X.009's. I put thinner washers on yesterday and that cleaned up a lot of the haze at idle. They also didn't have that problem when I had them in the 1990. Oldestof11, they're definitely not pods as the pop pressure is 245 bar, and I've always gotten better mileage with these injectors compared to ic or n/ic injectors. Pods tend to reduce mileage in most cases from what I've read. Looks like I gotta buy 145 spray angle injectors before I melt the pistons (Thats what I told the old lady last night :lol: ) Sorry for hijacking..
Postby cougar » Sun Apr 10, 2011 8:48 am
Getting confused here.
The injectors I removed from my 91 where as described in the original post. They have a 5X.012' (I measured it) on what looks like a VCO nozzle. Not original to the bodies.
The injectors I installed where new Bosch 0432131837 without any modifications. They are not Lucas PODs.
I didn't have any haze problem with them until I put the 4" exhaust on. To fix that I had to go to a larger turbo.
Will this 155° spray pattern be a problem as Remps suggested? I use this truck for towing a lot.
cougar
Postby Smokem1 » Tue Apr 19, 2011 8:56 am
cougar wrote:nozzle is 5 hole
9745
I looked them over yesterday, just for reference to anyone interested that may have the same nozzle and is curious, they are VCO 155° cone angle 5x0.012".
Smokem1
Postby cougar » Wed Apr 20, 2011 10:31 am
Thanks for looking them over.
cougar
