Ve mods?
Ve mods?
Postby Cnp22 » Mon Apr 04, 2011 1:40 pm
I'm pulling the ve off my auto to put on my getrag truck and puttin the p-pump stuff on the auto. My ? Is what can I do if anything to the ve while I got it off? Iv got the full power screw bottomed out, pin shaved, and a spring in it. Anything else I can do while it's off for power? Reliability?
1992 auto, pump mods, 5x16's, 66/74, 8.9 1/8th
1992 getrag, p-pump, 540hp 1300fttq, 8.4 1/8th, 13.2 1/4
Cnp22
Re: Ve mods?
Postby fatty » Mon Apr 04, 2011 7:03 pm
You could loctite the front seal in if you plan on running more fuel pressure later.
Re: Ve mods?
Postby ahale2772 » Tue Apr 05, 2011 6:04 am
I took all the fittings off of my spare pump and brought them to my local parker fluid connections store, got a new fitting for the inlet before the vane pump and some for a future dual feed deal...essentially just freed up some extra room for flow and nice 3/8 fuel lines
Re: Ve mods?
Postby Cnp22 » Tue Apr 05, 2011 10:50 am
I plan on loctiteing the seal in, it's been holding 22psi for about two weeks now. How do you duel feed the ve?
Cnp22
Re: Ve mods?
Postby ahale2772 » Tue Apr 05, 2011 11:49 am
Do some searching on older posts kta and cummins king had dual feed setups
Users browsing this forum: No registered users and 62 guests
