85 F350 Crew Cab 4WD 12V Swap
Postby GPSMatt » Mon Mar 28, 2011 1:33 pm
First off here are some pics of the truck.
The truck is an 85 I picked it up on craigs list for $1000! I had a nother crew cab F-350 I was going to do the swap on but it sat to long without a motor an ex gf broke the windshield and I ended up parting it out.
Here are pics of the progress so far.
Fork Lift FtW bye bye 460
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Re: 85 F350 Crew Cab 4WD 12V Swap
Postby GPSMatt » Mon Mar 28, 2011 3:14 pm
Next up firewall modifications
Before
After
First fender done
The entire engine compartment well look like that when done.
The aftermath of 2 days of work.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby GPSMatt » Mon Mar 28, 2011 3:15 pm
The motor came out of a 93 D350 I wish I had pics of the truck but here is a video.. [url="http://www.youtube.com/watch?v=7GAStTOA0HM"]http://www.youtube.com/watch?v=7GAStTOA0HM[/url]. At the time I drove tow trucks and the truck came to the yard as a DUI I got it from my boss for $500. It ran amazing I drove the **** out of it for several months until the getrag got stuck in 4th gear. I than drove it for another month in 4th gear until the clutch burned out.
As it sits now. Killing the KDP and resealing everything.
THe NV4500 was another sweet deal. Its got some rust from sitting for the last 3 years but it should clean up nice. Another craigs list score $500. The trans has been rebuilt and has the updated 5th gear nut.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby dazedandconfused » Mon Mar 28, 2011 3:26 pm
I love those old Ford's. I had an 86 I regret selling everyday.
Postby Mark Nixon » Mon Mar 28, 2011 6:22 pm
Always liked the fender flares on a Ford dually, they have bulk to them.
I take it you're planning on tabbing a dowel pin, at least? :lol:
Postby PToombs » Mon Mar 28, 2011 6:30 pm
Don't forget to take that wrench outta the intake, you'll tear your hair out trying to find that rattle in it! :lol:
Postby Richie O » Mon Mar 28, 2011 7:37 pm
PToombs wrote:Don't forget to take that wrench outta the intake, you'll tear your hair out trying to find that rattle in it! :lol:
I did that on a small block once. Put the intake on and then pulled my hair out looking for all the missing tools. Took the intake off and it had lots of wrenches and a ratchet. :roll: It was a late night.
Postby ellis93 » Mon Mar 28, 2011 7:47 pm
Hey Mr Richie I did the same but with rags. I only found it cause I couldn't get the distributor in :mad:
Postby GPSMatt » Mon Mar 28, 2011 10:29 pm
Thanks guys and yeah the wrench well come out lol.
Mark Nixon wrote:Always liked the fender flares on a Ford dually, they have bulk to them.
Yes tabing the dowel pin pulling the pump to make installation of the 366 spring easier and doing a new seal in the front.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby GPSMatt » Fri Apr 01, 2011 9:39 am
Some goodies from advanced adapters arrived. BTW if any one needs anything from them shoot me a PM I am now a distributor.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby GPSMatt » Sat Apr 02, 2011 11:52 pm
Motor looking good all ready to drop in.
Valair 13inch fly wheel and clutch. 400hp and 900ftlbs
mmm all ready to roll. Take not of the $100 used clutch fork I had to buy because I didnt think I would need the getrag one from the parts truck.
Almost in thank god for a fork lift.
Need to finish the engine compartment.. and figure out what color I want to paint my valve covers.
Looks like I will need to go in from behind to make room for a 4 inch DP
Now the the motor is in the easy part is out of the way.
ZF5 in my 86F250
Look how far back the NV4500 is. Need to figure out something different for Tcase shifter.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby GPSMatt » Mon Apr 04, 2011 7:58 pm
Red valve covers and injection lines it is.
I need to re-clock the turbo but running the manifold upsidedown gave me more than enough room.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby thumpertrev » Tue Apr 05, 2011 7:52 pm
Lookin good! Looks like we're doing two different breeds of the same dog. Mine started out as a 2wd also.
1994 Ford crew cab dually.Turbos-WH1C over a TV8102,3" charge piping,largest aluminum I/C I could fit,5" turbo back,SDX11 5x12,mild head porting,ARP studs,Throttle mod,ground pin,366 spring, fuel screw bottomed(no runaway),A518 with low stall converter.
thumpertrev
Postby dazedandconfused » Wed Sep 28, 2011 2:25 pm
Been a while any updates?
Postby oldestof11 » Wed Sep 28, 2011 2:32 pm
Not to be a downer but that ZF5 is a better trans than the NV4500...
