ahale2772 wrote:check out the injector breakdown thread, its got lots of good info.
you need to note the style of tip as well as the size, a sac nozzle may be less efficient than a VOC, even if they are both 6holers of the same size
usually the spary angle is a function of what year of the truck....noIC is 145*, i believe IC is 155*
hence even if you get an efficient injector with the wrong spray angle you wont be very happy with results
You have it backwards. 155 non cooled, 145 cooled.
ahale2772 wrote:You have it backwards. 155 non cooled, 145 cooled.
gotcha, thanks Richie... and oh yeah no cooled has 7mm tips and cooled has 9mm (DOHH).. mix them up all the time too
also interesting to not that some 6holers have 3 small holes and 3 larger holes
oldestof11 wrote:Lexdysic?
cougar wrote:This is something I've wondered about myself. Never found a good answer to it either.
So let me throw this thought out there and see what you think.
Compare a 6 hole and a 5 hole injector with equal cross sectional area and all other factors being the same;
6 hole I would think would give you better atomization at lower throttle because of smaller holes, but might become a restriction at high flow WOT.
5 hole may not give as good atomization at lower throttle, but the bigger holes may have less restriction at high flow WOT and atomization improves.
you mean the non intercooled trucks have 9mm and intercooled trucks have 7mm right?
ahale2772 wrote:you mean the non intercooled trucks have 9mm and intercooled trucks have 7mm right?
I was just joking that time...honest, Pete allready put me in my place on that one a while back
oldestof11 wrote:No pete. It is what your boyfriend uses.
Douglas wrote:cougar wrote:This is something I've wondered about myself. Never found a good answer to it either.
Time to get out the Fluids text again...W/O getting out the book to determine exactly ,the more holes for a given area the lower the flow will be at a given pressure...and since the pump is going to try to deliver a particular volume, more holes will up the pressure which seems to lead to a better spray/atomization.
cheers,
Douglas
