Pump top reseal and 366 spring
Postby Horus » Wed Apr 06, 2011 9:41 am
I recently resealed my pump top and installed the 366 spring while I was in there. Here is a link to my Jeep club's forum where I posted the writeup. If there is enough intrest I could try and copy/paste it into it's own thread on here.
http://www.pnwjeep.net/forum/viewtopic.php?f=51&t=26570
What do ya'll think?
91.5 W250 Dodge 4X4 CTD. Getrag. DD Power pin removed, stock fuel cone back in. 366 spring. Power screw at stock depth. Stock turbo. Stock lift pump. Straight piped and Intercooled.
93 D250 Dodge club cab 2wd. All stock for now. Automatic.
Hard KOR Wheeler.
PNWJeep club member.
Horus
Re: Pump top reseal and 366 spring
Postby Richie O » Wed Apr 06, 2011 10:22 am
There is intrest. If you can, make a thread here with all the pics too.
Postby 1990 » Wed Apr 06, 2011 10:34 am
Good write up. I'd bring it over here. I'll be doing the 366 and a couple weeks.
2012 Subaru WRX TP Stage 1 DD
Postby ellis93 » Wed Apr 06, 2011 10:44 am
Very nice write up. Yes please post it up ;-)
Postby ahale2772 » Fri Apr 08, 2011 8:21 am
agreed, great write up, I never had a good grasp on how to push the afc pin / lever out till now , im guessing that shaft with the 2 balls holding it in is what holds the afc lever on? so all one would have to do is pull the pump top, push that pin out and remove the lever? ... can someone confirm that?...never got a good grasp on that before cause im a visual "give me pictures" kind of guy
my favorite part of that write up...
"When I removed the fuel screw is when tragedy struck. The tamper collar just up and fell off! It was terrible."
Postby Tacoclaw » Sat Apr 09, 2011 6:08 pm
I liked that part as well, ahale, not to mention his completely relatable experience with brake-clean in his eyes. Mine was carb cleaner, but still. :lol:
Excellent writeup btw, Horus. I appreciate you taking the time. 8)
Postby ahale2772 » Tue Apr 12, 2011 4:58 am
yeah I know, any of you guys seen the articles floating around about brakleen when it is burnt off something? releases some super toxic nerve gas...not an experience I want to relate with :shock:
Postby ellis93 » Tue Apr 12, 2011 5:22 am
ahale2772 wrote:yeah I know, any of you guys seen the articles floating around about brakleen when it is burnt off something? releases some super toxic nerve gas...not an experience I want to relate with :shock:
Not good!
Postby ahale2772 » Tue Apr 12, 2011 5:41 am
this was from the haisley machine website.... http://www.brewracingframes.com/id75.htm
Postby ellis93 » Tue Apr 12, 2011 7:02 am
Life is backwards. Why is it that hard working, or just workin folks have to deal with stuff like this.
Postby PToombs » Tue Apr 12, 2011 5:35 pm
I saw that just last week too. I use brake cleaner all the time, and sometimes to clean oil off before i weld. Not any more! :shock: Phosgene gas is bad siht, pretty sure that's what they used in WW1.
Postby oldestof11 » Tue Apr 12, 2011 6:42 pm
Since no one here said anything...
1st, nice write up! Post over here to help some of the guys.
2nd, your AFC pin is going down TOO far. Notice how it rides up a little from the deepest point? Take a grinder to that thing and make it deeper/higher for more power.
Postby ahale2772 » Wed Apr 13, 2011 5:23 am
^ agreed, and you can see that the pin is so deep that it bottoms out the little pin, my denny t does that as well....no leak yet...crossing my fingers....but it may have atributed to why your pump leaked in the first place
Postby 1990 » Sat Apr 30, 2011 10:28 am
Just installed the 366. Just a awesome upgrade for the cost. 8) 8)
