Purchasing Turbo Friday...HELP
Re: Purchasing Turbo Friday...HELP
Postby oldestof11 » Sat May 14, 2011 9:54 am
The VE pump fuel hard to that point. The 2200 will be the stock 2800 RPM and the 2900 is the 3200 RPM spring we all (except the old guy in the NW side of the country. Sorry Rich! :lol: ) love to swap in.
The VE, in order to maintain a max RPM limit, starts cutting the fuel off after so many RPM's before flat lining at the springs tension.
The thing to worry about when selecting the turbo is what RPM's you will be pushing most. If all you do is tow and occasionally play, the smaller turbine will help. If you race constantly, get the bigger one. At higher RPMs, the smaller one will "choke" and get hot.
Postby Richie O » Sat May 14, 2011 11:04 am
North east my friend, north east! :D I ain't no left coaster. ;)
Postby RATROD92 » Thu May 19, 2011 4:30 am
oldestof11 wrote:The VE pump fuel hard to that point. The 2200 will be the stock 2800 RPM and the 2900 is the 3200 RPM spring we all (except the old guy in the NW side of the country. Sorry Rich! :lol: ) love to swap in.
Thanks
I ended up ordering a PDI exhaust manifold and a silver series 64/74/14 with a 4" down pipe....If this ain't enough, I'll change the injection pump....lol.... :roll: weather is finally getting nice here....took forever this spring...
I should get it in about 7 - 10 days....
James
92 D350 shortened 2 feet, 56 Ford F100 Cab, VE Pump maxed 12mm, Denny II, PDI exhaust manifold, Silver Bullet 64/74/14, SCHEID 6X.016's, 5 speed Getrag, 400 horse clutch, 3.54:1 rear, Air Dog II 165, Aluminum Radiator, Pump to head, 3800 R.P.M. spring...Puts a smile on my face when its lit....
RATROD92
Postby oldestof11 » Thu May 19, 2011 12:56 pm
IF you need help, lemme know. Give me a day or 2 advanced notice and I should be able to help.
Postby RATROD92 » Thu May 19, 2011 4:10 pm
oldestof11 wrote:IF you need help, lemme know. Give me a day or 2 advanced notice and I should be able to help.
Thanks man that's really nice of you....but I'm pretty quick ....I changed all my injectors in 30 minutes....the second time.....lol
this thing will be on the day I get it I'm sure....with just the 4" down pipe and no exhaust for a test drive.. :D
James
RATROD92
Postby The_Head » Fri May 20, 2011 12:58 pm
bgilbert wrote:I would highly recommend calling Mark Burris at Turbo Diesel & Injection in Indianapolis, IN. He will custom build you anything you want. You pick what compressor housing, turbine housing, and wheels you want, not some dealer selling you a prepackaged HTT, II SB, or the like turbo. Not too mention I see a guy on CF has been selling 1st gen guys S300's with the 3rd gen compressor housings :roll: :roll: :roll: :roll: :roll: . 1-800-232-2834. Make sure you talk to Mark Burris.
I called Mark today for S&G's. He recommended a 64/71/12 for what the info I gave him on my truck. The thing is the price... $1675. That is pretty much II/HTT/PDR/ATS etc etc pricing. I am sad now.
The_Head
Postby bgilbert » Fri May 20, 2011 5:20 pm
Not to start a price war, but according to HTT's site, it's $2100 for that turbo. http://www.htturbo.com/ht71.htm. Granted you can usually save a buck or two if you buy from an HTT dealer and not direct, but $400?
Bill Gilbert
Postby The_Head » Fri May 20, 2011 5:45 pm
Oh it's ok. I guess I was just expecting super cheap prices since its coming from a non famous supplier.
The_Head
Postby dazedandconfused » Fri May 20, 2011 5:46 pm
Call Forced Inductions. Not seen anyone even close to their prices on anything I've asked about.
Postby The_Head » Fri May 20, 2011 6:17 pm
I will but I won't be expecting much.
The_Head
Postby dazedandconfused » Fri May 20, 2011 6:42 pm
He was a $1000 cheaper for the same spec 2.6 charger I was priced from the big name companies.
Postby The_Head » Fri May 20, 2011 6:44 pm
I don't know how much a 2.6 charger is, but that sounds promising.
The_Head
Postby dazedandconfused » Fri May 20, 2011 7:04 pm
http://www.forcedinductions.com/productsborgwarner.htm
They can build anything custom as well.
Postby RATROD92 » Thu May 26, 2011 10:49 am
Well....I put on my silver 64/74/14 along with a PDI exhaust manifold......Took it for a ride and all I can say is not impressed....my little H1C had a little more grunt on the low end....but this does pull harder from 2300 R.P.M. and up... but not nearly as much as I would like....I cant get more than 35 lbs of boost....will not go past... my little H1C hit 34 lbs....
I'm guessing I need more fuel....as I only have 5 x 12's :|
James
RATROD92
Postby AHineman » Thu May 26, 2011 11:44 am
Time for some 6x.016s. :lol:
