Injector Question
Injector Question
Postby collegekid » Sun May 15, 2011 3:28 pm
What do ya'll think of SDX Injectors 5x.014 for a tow/daily driver, coupled with 4" exhaust, BHAF, Fuel Pin, 3200 spring, dual electric fans, 14cm exhaust housing, pump maxed and 60mm compressor wheel upgrade?
collegekid
Re: Injector Question
Postby PToombs » Sun May 15, 2011 4:35 pm
Never make it, too hot. The 60mm wheel on the stock compressor won't flow enough air to keep it cool, especially towing. I have more air mods than you, smaller injectors (5x.012) and hit 15-1600 at top end just stomping on it. Towing is an excerise in misery as I try to keep it cool when pulling hills. Bigger turbo is the way to go, or a set of twins.
Postby collegekid » Sun May 15, 2011 5:24 pm
What size single you thinking....how about water/methanol?
collegekid
Postby cougar » Mon May 16, 2011 7:49 am
What I have in my sig for the 91 is a good towing set up. Most important, I don't have the fuel screw cranked in much.
01 2500 "the work truck".
cougar
Postby collegekid » Mon May 16, 2011 9:22 am
How does the timing device work, I see it appears to be just a spacer, but whats the mechanics behind it?
collegekid
Postby cougar » Mon May 16, 2011 1:37 pm
collegekid wrote:How does the timing device work, I see it appears to be just a spacer, but whats the mechanics behind it?
It simply increases the distance the piston can travel allowing for more advance as case pressure builds with RPM. Some people shave the piston to accomplish the same thing. You can still bump the pump timing, but for towing you want to retain as much of your low end torque as you can.
cougar
Postby collegekid » Mon May 16, 2011 2:48 pm
Ahh, gotcha, I know these trucks arent designed to have both low and high end torque unless theyre twin-turboed, so what is an alternative to twins that will get me the low end torque I need for towing, but also high end torque and hp for everyday highway driving?
collegekid
Postby collegekid » Thu May 19, 2011 12:31 pm
toombs, if I ran that same setup as I started with, with 7x10 injectors, and a s300 64 coupled up to a s400, you think that'll move enough air
collegekid
Postby oldestof11 » Thu May 19, 2011 12:51 pm
7x10's I think are smaller than 5x14's...
Get the 5x14s with a good twins set up (s300 62 over s400 would be good) and love it.
Make sure you get a nice clutch!
Postby collegekid » Thu May 19, 2011 2:29 pm
Oldest, Im thinking a 13" Southbend clutch, and you think Ill need an upgraded input shaft? There are some decent sized hills around here and I dont wanna be halfway up one and snap the splines over
collegekid
Postby AHineman » Thu May 19, 2011 2:33 pm
I don't think anyone makes one for the Getrag.
Postby collegekid » Thu May 19, 2011 2:35 pm
Oh, :oops: well that answers that question, as long as the tranny will hold up to whats going through it ill be happy 8)
collegekid
Postby oldestof11 » Thu May 19, 2011 2:37 pm
You want the smaller input shaft size. 1-1/4" IIRC....
Yes definitely 13".
The Con-OFE or Con-FE for the best holding power.
Call them up and ask for Peter. Great guy to deal with!
Postby collegekid » Thu May 19, 2011 2:39 pm
Sweet Thanks bud for the connection.....IIRC???
collegekid
Postby oldestof11 » Thu May 19, 2011 3:46 pm
if I remember correctly.
Users browsing this forum: No registered users and 62 guests
