Engine computer ?
Engine computer ?
Postby GIT-R-DONE » Sat Sep 22, 2007 5:03 pm
My question is : are all the engine computers the same for our trucks? Will a 91.5 intercooled ECM (if that matters) work on a 93, or vis versa? Are automatics compatible with the sticks?
GIT-R-DONE
Postby wannadiesel » Sat Sep 22, 2007 6:18 pm
The '91.5 PCM is unique to that year.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Sat Sep 22, 2007 7:57 pm
wannadiesel wrote:The '91.5 PCM is unique to that year.
Unique to what year?
The year from 91.5 to 92?
Postby wannadiesel » Sun Sep 23, 2007 6:00 am
Only '91.5 trucks use that PCM.
Best dyno: 408/844
wannadiesel
diesel guru
Postby TWorline » Sun Sep 23, 2007 6:06 am
Did they still use the external voltage regulator on the 91.5?
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby wannadiesel » Sun Sep 23, 2007 12:51 pm
Yes.
Best dyno: 408/844
wannadiesel
diesel guru
Postby PToombs » Sun Sep 23, 2007 5:16 pm
Stick and auto should be different too. Auto has the TPS, I'd be surprised if it was the same. I could be wrong though.
Postby dpuckett » Tue Sep 25, 2007 2:36 pm
I believe the PCM from a stick to auto will interchange, as long as it's 91.5 to 91.5 or 92/93 to 92/93. I have swapped with Mom's (known good, auto) a time or two for troubleshooting, and nothing was amiss.
Daniel
