A/C
both inside and out
A/C
Postby pulltilbroke » Tue May 31, 2011 8:54 pm
Yesterday I replaced the reciever drier, expansion valve and chopped in a condensor in an attempt to get the A/C working. Just gotta vac it down and see if she's good.
Hopefully be able to cruise to Michaels place in two week with cool air blowing in my face. :D
Re: A/C
Postby Gots_a_sol » Wed Jun 01, 2011 9:03 am
you could have at least got it level :lol:
-Joe
Gots_a_sol
Re: A/C
Postby Tacoclaw » Wed Jun 01, 2011 1:08 pm
Coming from a guy with no hope of ever having AC on his truck again, I think it looks fantastic.
Re: A/C
Postby pulltilbroke » Wed Jun 01, 2011 5:05 pm
Gots, Looks good to me :D
Taco, Why no hope of A/C???
BTW, alot of cutting was required on the lower filler panel. :lol:
Re: A/C
Postby Tacoclaw » Wed Jun 01, 2011 5:32 pm
My water pump for the air/water IC sits where the AC compressor used to, I took out everything from the condenser to the heater core and chucked it...somewhere.
It's not so bad, once you get the wing glass and the kick panel opened up. I'd still totally kill for AC though.
Also, glad to see I was completely wrong about fitting stuff behind my non-IC grille. :lol:
Re: A/C
Postby pulltilbroke » Wed Jun 01, 2011 5:47 pm
I've never had a vehicle with working A/C so I know where your at Taco.
Yeah originally I was told an intercooler wouldn't fit up there with out goin to a 91 up grille. Guess it just depends how much stuff you want to cut up.
Re: A/C
Postby slow_90firebird » Fri Jun 03, 2011 9:26 am
Tacoclaw wrote:Coming from a guy with no hope of ever having AC on his truck again, I think it looks fantastic.
Not in stock form... You could always use an electric a/c compressor and modify the stock lines to work.
slow_90firebird
Re: A/C
Postby pulltilbroke » Sun Jun 05, 2011 9:25 pm
Well evaced the system tonight and tried charging it but the filter in the line is plugged so........
Re: A/C
Postby RumbleFish » Mon Jun 06, 2011 8:16 am
Sounds typical. You're supposed to put in a new filter everytime you open the system. A new expansion valve wouldn't hurt either, and both are fairly cheap.
Re: A/C
Postby pulltilbroke » Mon Jun 06, 2011 9:04 pm
I did replace the reciever/drier and expansion valve, the thing thats givin me fits is that muffler of filter or whatever it is inline right behind the compressor.
Re: A/C
Postby pulltilbroke » Tue Jun 28, 2011 9:16 pm
Well the AC works now, Had to cut a hole in the HVAC box the clean out the evap core, It now blows a lot harder out the vents and with the AC on it blow 44 degree air!!! Should be good enough for me. This will be weird I've never had a vehicle with working air.
Heres some pics of what it looked like.
Re: A/C
Postby PToombs » Wed Jun 29, 2011 5:09 pm
Wow, that's some nasty siht right there! Common though if it's never been done. Enjoy that air, all I have is 2-60 in mine. :cry:
Re: A/C
Postby pulltilbroke » Wed Jun 29, 2011 8:29 pm
Yeah it was nasty shti I spent about two hours standing on my head cleaning it out with a pick.
I did however get to test it today, It was mid 90s with a heat index of 105 and it cooled good enough to give me frosty nipples :lol:
Hey Pete, Why don't you put a rear slider in there?
Re: A/C
Postby Mark Nixon » Thu Jun 30, 2011 10:55 am
pulltilbroke wrote:....it cooled good enough to give me frosty nipples :lol:
Hey, Dammit, I could use a set of those! :shock:
The DAMNCHARGER's air is all hooked up, I think all it needs is a vacuuming down, oiled and charged.
Re: A/C
Postby ellis93 » Thu Jun 30, 2011 11:34 am
I can't wait to see what he comes up with to respond to that :lol:
Return to Body
