2wd auto to 4wd 5sp
2wd auto to 4wd 5sp
Postby cmann250 » Fri Jun 03, 2011 1:11 pm
Is it worth converting my truck? Or should I just find a 4x4 5 speed?
I saw a 4x4 5sp truck that was diesel, minus the engine for $1500. Is that reasonable?
I bought my truck for $1500, put another $1500 in it to get it working right, so of i were to sell it i'd want at least $3500.
Re: 2wd auto to 4wd 5sp
Postby dazedandconfused » Fri Jun 03, 2011 4:28 pm
Cheaper in the long run to sell unless you can find a cheap donor truck.
Postby Tacoclaw » Fri Jun 03, 2011 4:50 pm
If that truck had the Getrag (or whatever 5-speed it has installed) and the 29 spline 205, I'd say it's probably worth $1500 if it's halfway solid. You can always pick up another VE Cummins and drop in there
The time investment involved with converting a 2x to a 4x would probably make up any more of that $1500 pretty quick, but that's only if you can track down a decently-priced Cummins to throw in it.
