Here's an odd question, regarding turbos
Postby eyoung429 » Wed Sep 26, 2007 4:15 pm
Can I take out the shaft, impeller and block the hole in the cartridge that the shaft goes through..put the turbo back in the truck..can I drive the truck in this manner till I get a replacement turbo???
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby PToombs » Wed Sep 26, 2007 4:24 pm
I don't recommend it! I know it's going to smoke like a pig, and EGT's are going to be really high. You're going to need something more than a plastic plug to seal the shaft hole. The air going by there is going to be in the above 900* range. Plus, it has to seal the oil in.
Postby eyoung429 » Thu Sep 27, 2007 5:47 am
I was going to cut the shaft and peen the bearings around it to hold it in place.....
already considered duct tape, bubble gum, paperclips, JB Weld........:)
eyoung429
Postby rbrettctd » Thu Sep 27, 2007 6:45 am
I think Id park the truck til the replacement comes in...
Randy
rbrettctd
Postby dpuckett » Thu Sep 27, 2007 6:48 pm
Ditto what he said. If you HAVE TO move it, you can start and idle around with no turbo, as long as you have a place for oil to go.
Daniel
Postby Rampower » Tue Oct 09, 2007 7:13 am
Are you looking for a stock turbo to put in place? I have a couple of holsets I use for door stops tha I may get rid of.
92 ext cab 4x4. HT62-14, 4" straight pipe, BHAF, O-ringed, Haisley head studs, Ported head, exhaust, and turbo. Fuel pin, 4,000 gov spring,
Rampower
