4 ways gliching
4 ways gliching
Postby manyholes » Fri Jul 08, 2011 6:58 pm
anyone had this issue? 4 ways wont work unless i put my turn signal on either way and key on. fuses good, lights good, everything under the dash looks good, had this issue before my overcharging incident. thanks
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Re: 4 ways gliching
Postby oldestof11 » Fri Jul 08, 2011 10:37 pm
How about the 4 way flasher module? Is it new? If not, try replacing it.
Re: 4 ways gliching
Postby manyholes » Sat Jul 09, 2011 7:59 am
where is the module? i changed the relays on the fuse board when i got the truck, never fixed the problem
manyholes
Re: 4 ways gliching
Postby Tacoclaw » Sat Jul 09, 2011 10:21 am
If this is the same truck that had the wild overcharging problem, what are the odds it blew out the 4-way's fusible link? It may not have power, but when you hit the hazard switch it back-feeds voltage through it and makes all 4 work.
Re: 4 ways gliching
Postby manyholes » Sat Jul 09, 2011 11:41 am
same truck taco, had this issue before the 18+volts pumped thru it
which fuseable link is for the 4 ways under the hood?
manyholes
Re: 4 ways gliching
Postby Mark Nixon » Sun Jul 10, 2011 9:30 am
manyholes wrote:which fuseable link is for the 4 ways under the hood?
Just start tugging at the insulation, you'll find the bad one(s), if there are any.
The Hazard flasher is located on the fuse box, along with the turn signal flasher.
The last thing would be a bad multifunction switch, where the turn signals, hazards, wipers, washer and junk are.
Return to Electrical
