vwkaferman wrote:Shoot. I've got my power screw ALL the way in, feels like a dog. Wouldn't start after I had the VE pump out for a few seals replacement. Someone here recommended turning the screw in, wala, started. Would this indicate that the throttle shaft needs to go a notch or two the other way? Sorry for the thread jack, thought appropriate since we're talking about the fuel screw.
James
cmann250 wrote:If your fuel screw is all the way in, you'd almost surely have run away, unless your throttle was indexed wrong
Richie O wrote:cmann250 wrote:If your fuel screw is all the way in, you'd almost surely have run away, unless your throttle was indexed wrong
Not all pumps will. My 89 will, my 93 will not.
