3 and 1 gauges
3 and 1 gauges
Postby flyinredneck » Sat Jun 25, 2011 4:03 pm
just bought a new 3 and 1 gauge with egt boost and tranny temp how do i install the boost gauge, and what is better to mount the egt probe pre or post turbo?
1992 w250 stock straight pipe with pump a lil tweaked denny t stage 2 fuel pin fuel screw at 3 turns
flyinredneck
Re: 3 and 1 gauges
Postby collegekid » Sat Jun 25, 2011 4:25 pm
The boost gauge should have an airtight line run from the gauge to the intake, directly under the intake horn is a bolt that you remove and plumb in your line......EGT probe pre-turbo is more accurate as the turbo will cool down the temp 200-300 degrees
Show some pics of the gauge and mounting plz :grin:
collegekid
Re: 3 and 1 gauges
Postby flyinredneck » Sat Jun 25, 2011 4:32 pm
ok it shopuld arrive anyday and i will. thanks
flyinredneck
Re: 3 and 1 gauges
Postby dazedandconfused » Sat Jun 25, 2011 4:44 pm
Who makes this gauge?
Re: 3 and 1 gauges
Postby oldestof11 » Sat Jun 25, 2011 4:54 pm
Glowshift.
Some people don't like that they aren't accurate like Autometer but for 1/3 of the cost, and just for monitoring like I did, I couldn't beat the cost...
http://www.glowshiftdirect.com/
They make different ones. Check them out.
Re: 3 and 1 gauges
Postby flyinredneck » Sat Jun 25, 2011 5:27 pm
how unaccurate are they
flyinredneck
Re: 3 and 1 gauges
Postby Richie O » Sat Jun 25, 2011 6:05 pm
flyinredneck wrote:how unaccurate are they
You tell us when your pistons drain out with your oil. :D
Over the years I have seen lots of temps that are not correct. People are running huge injectors and they have low egt's with a small turbo. Some gauges ( all brands ) are just not exact.
Re: 3 and 1 gauges
Postby 1990 » Sat Jun 25, 2011 8:12 pm
Mine is accurate. The gauge is compact and cheap what else do you need?
Right click and view image on my avatar, it's a good gauge for majority of users.
I've posted this picture a billions times. If you did a google search you would found the answers to you questions.
First sensor is the boost. The circled one is the fuel pressure if you had got that with gauge.
2012 Subaru WRX TP Stage 1 DD
Re: 3 and 1 gauges
Postby AHineman » Sat Jun 25, 2011 8:24 pm
1990 wrote:If you did a google search you would found the answers to you questions.
No one made you answer. ;)
We were all newbies once. 8)
Re: 3 and 1 gauges
Postby flyinredneck » Sun Jun 26, 2011 1:07 pm
thanks 1990 i got egt boost and tranny temp but im also getting a fuel pressure gauge seperatly did you get your fuel pressure in the combo gauge
flyinredneck
Re: 3 and 1 gauges
Postby BILTIT » Sun Jun 26, 2011 2:10 pm
I have fuel pressure in my 3n1.
Derek B.
BILTIT
Re: 3 and 1 gauges
Postby 1990 » Mon Jun 27, 2011 2:15 pm
True
flyinredneck wrote:thanks 1990 i got egt boost and tranny temp but im also getting a fuel pressure gauge seperatly did you get your fuel pressure in the combo gauge
Yes. 3n1 with fuel pressure instead of temp sensor.
Re: 3 and 1 gauges
Postby flyinredneck » Thu Jul 14, 2011 9:52 pm
1990 your fuel sensor looks like my boost
flyinredneck
Re: 3 and 1 gauges
Postby 1990 » Fri Jul 15, 2011 4:05 am
flyinredneck wrote:1990 your fuel sensor looks like my boost
Yes because its the same sensor. Notice the wires are the same colour.
Re: 3 and 1 gauges
Postby flyinredneck » Fri Jul 15, 2011 8:06 am
what size nipple did you use on your boost
flyinredneck
