injection pump
injection pump
Postby Hansen01 » Wed Jul 20, 2011 4:13 pm
http://kansascity.craigslist.org/grd/2504390630.html
anyone know if this injection pump is for a intercooled or non intercooled? guy said he wasnt sure, or does it matter? also made in germany? jus looking for some advice
Under construction...
Hansen01
Re: injection pump
Postby Remps » Wed Jul 20, 2011 4:43 pm
Right by the fuel kill lever on that square plate where it says made in germany, it'll have the numbers 184 (N/IC) or 205 (I/C).Either one will work, KSB is different on the two pumps, as well as a slight difference in the camplates.
Re: injection pump
Postby Hansen01 » Wed Jul 20, 2011 4:45 pm
ok thanks! jus what i was looking for :D
but are they all made in germany? was jus a little confused about that jus thought theyd be made in usa
i do not see 205 or 184 on it, i guess il have to ask him
Hansen01
Re: injection pump
Postby oldestof11 » Wed Jul 20, 2011 6:55 pm
Engine made and assembled in USA.
Fuel system from das motherland, Germany.
Re: injection pump
Postby Richie O » Wed Jul 20, 2011 7:00 pm
When did they start brazil blocks? :roll:
Re: injection pump
Postby Hansen01 » Wed Jul 20, 2011 7:12 pm
alright thank you, jus wanted to make sure that they were made in germany and not some aftermarket junk pump or somethin :D
Hansen01
Re: injection pump
Postby oldestof11 » Thu Jul 21, 2011 12:58 pm
Richie O wrote:When did they start brazil blocks? :roll:
:scratch:
Re: injection pump
Postby dazedandconfused » Thu Jul 21, 2011 1:21 pm
I thought it was late 90's like 96, 97.
Re: injection pump
Postby PToombs » Thu Jul 21, 2011 4:39 pm
The Brazil blocks are the "53" blocks, '99ish I believe.
Re: injection pump
Postby Richie O » Thu Jul 21, 2011 6:17 pm
PToombs wrote:The Brazil blocks are the "53" blocks, '99ish I believe.
Some guys on NETDP said even some late p pumpers had the 53 block. It was a choice of Brazil, or what?, mexico. Somuch for american steel. I had my share of brazil blocks with the ford ranger 2.0's junk!
Re: injection pump
Postby peobryant » Thu Jul 21, 2011 6:41 pm
My father and brother both have '97's with a #53 block, and a close friend has an '01 with a #53 block. It seems the years are all over the place.
