stillsmokin also pulled this weekend
Re: stillsmokin also pulled this weekend
Postby pulltilbroke » Sun Jul 10, 2011 10:47 am
Jon, I already got a 241 swap in the works. Jeff on the other hand would have to regear again if he were to swap cases.
Dar, Don't be a wimp :lol:
Postby 1STGENFARMBOY » Sun Jul 10, 2011 3:33 pm
No wimpage here just financially challanged......... :cry: :cry:
plus i can't have the truck down in the summer for shur.......stupid farm chores. :x
Dar
Postby Richie O » Sun Jul 10, 2011 4:18 pm
1STGENFARMBOY wrote:No wimpage here just financially challanged......... :cry: :cry:
Dar
I don't even need mine for day to day operations and I still won't hook them up. I beat my trucks, but pulling is just to hard on stuff. I didn't even drag race last year for fear of busting stuff. May not this year for the same reason.
Postby oldestof11 » Sun Jul 10, 2011 5:28 pm
Richie O wrote:I don't even need mine for day to day operations and I still won't hook them up. I beat my trucks, but pulling is just to hard on stuff. I didn't even drag race last year for fear of busting stuff. May not this year for the same reason.
Dar, this here is a true wimp! :lol: Wont even put in a 3200 rpm spring.
Postby stillsmokin » Mon Jul 11, 2011 9:39 pm
Andy forgot to mention there are 3 different 271/273's in the garage, I will regear and swap t-cases later this year. I'm just ironing out the setup on the chassis before I reach for the 610cc p7100 and 5x20's, so the 205 needs to tough it out a just little longer. Damn monster ve's anyway, now they're tearing up np205's :P
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
Postby Mark Nixon » Tue Jul 12, 2011 1:19 pm
I'm of the opinion that the rear damage is a result of the front damage.
It's going to take a lot more than a tossed driveshaft CV to annihilate that 205.
You were rolling with a POTENTIAL of more than 300 feet on that pull when it kicked over on you.
Pretty amazing how they can be rolling on like thunder, then BANG, and it all stops moving. :shock:
Postby stillsmokin » Tue Jul 12, 2011 4:53 pm
Mark Nixon wrote:I'm of the opinion that the rear damage is a result of the front damage.
Yep you're right on Mark, when something lets go in the driveline all the torque immediately shoots to the remaining components. The front shaft tore off at the CV then the rear output saw an instant 200% increase in torque, the helical cut of the low gear thrusts on the rear bearing which is held by that seal retainer. When the shaft pushes out it unlocks the rear output from the sliding sleeve for low range and theres no go.
It was a $500 pass, but on the other hand, it sure ran hard.
stillsmokin
Postby ahale2772 » Tue Jul 19, 2011 11:43 am
"it was a 500 dollar pass"
...that does not sound bad, its all the time spent putting it back together that is the worst.
no internal damage to the 205 when that rear yoke pushed south?
Postby SuperSix-Two » Sat Jul 23, 2011 10:30 pm
Stupid rookie question, but whats the difference between a Light, Heavy, and Open hook?
Apparently we don't have sled pulls in the godless north for me to watch
1984 W350 Crew Cab Shortbox
SuperSix-Two
Postby Mark Nixon » Sat Jul 23, 2011 10:38 pm
SuperSix-Two wrote:Stupid rookie question, but whats the difference between a Light, Heavy, and Open hook?
I think those are classes.
I might be wrong, though. :D
Wouldn't be the first time. :roll:
Postby SuperSix-Two » Sat Jul 23, 2011 10:42 pm
I was wondering what the differences were
SuperSix-Two
Postby pulltilbroke » Sat Jul 23, 2011 10:58 pm
Light is usually 75 or 7700lb class, Heavy is usually 8300 or 8500, Open is just that run anything you want, and I mean ANYTHING.
Postby SuperSix-Two » Mon Jul 25, 2011 10:38 pm
Cool, thanks.
SuperSix-Two
Postby stillsmokin » Wed Jul 27, 2011 5:00 pm
The truck is back together and ran again Sunday. I tried what I was working on at Tecumseh 2 weeks ago when it scattered parts on the track. It worked this time I successfully pulled off 2, loud pedal on the wood, full boost launches, hello diesel tower we have ground speed. Don't try this stuff at home with your southbend con-fe. Turn up the sound and enjoy the sound of a VE doing the impossible. Thanks to Pulltilbroke and Dan for the video.
FWIW the track was biting and the two trucks in front of me scattered in the light class, one was a hard running second gen which apparently stripped the teeth off of the 80 rear.
http://youtu.be/ADqtVKVCM7Q
http://youtu.be/zfW0yzIeE7A
stillsmokin
Postby dazedandconfused » Wed Jul 27, 2011 5:14 pm
Looks good. Like to see that truck run out here on our sticky horse power tracks.
Return to Competition
