Water leaking into cab?
both inside and out
Postby Ironforger » Sat Jul 23, 2011 11:40 am
Ok,a while back I noticed dampness in the jute padding under the floor mat. Took all the floor mats/padding out to dry. Luckily I caught this in time before it started rusting, yes this truck IS rust free and I'd really like to keep it this way.
So I def gotta resolve this water leak issue before I put the padding back in. Driving me crazy, can't figure out where it's coming from. At least 3 sources it appears. When it rains, water drips down from somewhere up in the columns behind seats where the seat belt rolls up. Sliding rear window? Drip check sealer on roof? I sealed the gasket on the center cab brake light, didnt make any difference. Should I get a new window or window gasket?
Also drips in the front somewhere near where the floor meets the verticle plastic panel near your feet on both passenger and drivers side. Should I take out windshield and install new gasket & urethane? Or is it somewhere in the cowl?
Has anyone hammered this out & completely resolved water leak issues?
Thanks!
FOR SALE --> 1990 W250 5sp reg cab. 21 mpg. Aprx 145k. (odo broke last year) Fuel screw. KDP killed. Solid floors, rockers & cab corners. Pm me.
FOR SALE --> 1995 Izuzu NPR 16ft Morgan body/side door. 160k. 80 k on reb auto trans. 1 ton lift gate. Pm me.
2002 3500 6 sp Qaud cab 2 wd. 202k <-- One badass truck!
1999 VW beetle tdi. PP520 injec. Rocketchip st. 3. 45 mpg. 260k
Ironforger
Re: Water leaking into cab?
Postby dazedandconfused » Sat Jul 23, 2011 3:45 pm
Cabs have a tendency of leaking around the windshield.
Postby peobryant » Mon Jul 25, 2011 7:17 pm
Cracked cowls are extremely common in our trucks, so I'd take a look there.
Postby ellis93 » Mon Jul 25, 2011 7:26 pm
Return to Body
