radio and dome light
Postby skilletky » Thu Jul 02, 2009 2:18 pm
just found something interesting out, if your dome light fuse blows, your radio won't work. at least that is how it is on my truck. any one else ever have this problem?
skilletky
Re: radio and dome light
Postby collegekid » Sat Jul 30, 2011 5:52 pm
AHA, same problem, how the heck did you fix it, my dome light fuse receptor blows a new fuse every time
collegekid
Postby Hansen01 » Sat Jul 30, 2011 6:33 pm
:thumright: me to, i jus went over a bunch of bumps and it quit :D
Under construction...
Hansen01
Postby collegekid » Sat Jul 30, 2011 6:36 pm
tried that, keeps popping fuses
collegekid
Postby dazedandconfused » Sat Jul 30, 2011 6:50 pm
The wires in both trucks I parted to the dome light were rubbed raw behind the light. The 93 had the light removed and the wires taped up. Might be a good place to check.
Postby collegekid » Sat Jul 30, 2011 7:23 pm
Just pulled the dome light and wires look good, bulbs look good....I replaced the cigarette lighter fuse, seemed to work.
collegekid
Postby Hansen01 » Sun Jul 31, 2011 12:27 pm
hmmm, maybe il have to check them wires behind the light if it ever gets out of the bodyshop, i dont wanna have it start happening again tho ;)
Hansen01
Return to Electrical
