1800* know with video
Re: 1800*
Postby oldestof11 » Sat Jul 30, 2011 8:12 pm
S366 for 2.6" or S364 for 2.5" turbo limits.
Something like 66/78/14 or 64/74/14 I believe are good sizes.
Re: 1800*
Postby JQmile » Sun Jul 31, 2011 8:32 pm
I'd be curious at how fast the turbo is really spinning. 58psi is gnarly, but I bet it would be more like 40-45psi with an intercooler.
I'd check your timing too.
JQmile
Re: 1800*
Postby nova6511 » Mon Aug 01, 2011 6:35 am
How do you check actual timing on these engines.
nova6511
Re: 1800*
Postby AHineman » Mon Aug 01, 2011 1:49 pm
Timing light with a transducer on #1 injector line. I need to get one.
Re: 1800*
Postby nova6511 » Mon Aug 01, 2011 2:21 pm
Got a secound gen innercooler and all the pipping today for $100 so hope I can get the heat down
nova6511
Re: 1800*
Postby collegekid » Mon Aug 01, 2011 7:21 pm
keep us posted on what everything looks like post intercooler
collegekid
Re: 1800*
Postby nova6511 » Tue Aug 02, 2011 6:31 pm
Braving 106* temps out today I got the cooler in the old truck and took it for a drive.Makes 50psi and after a very long hard run in drive it finally hit the 1650 warning light.Im still hot but it took it 3 times longer to get there and it wasnt 1800.
nova6511
Re: 1800*
Postby collegekid » Wed Aug 03, 2011 12:30 pm
you gonna install a water kit?
collegekid
Re: 1800*
Postby nova6511 » Wed Aug 03, 2011 4:11 pm
I may for the street but the sled I pull will not allow it.I will proubly buy a HX50 and try to get the exhaust out faster,I just dont think I can lite it on the street.
nova6511
Re: 1800*
Postby Hansen01 » Wed Aug 03, 2011 9:28 pm
find a sneaky way to hide it :D :D
Under construction...
Hansen01
Re: 1800*
Postby nova6511 » Thu Aug 04, 2011 5:19 pm
I have thought about it.The one nise thing about a cluttered engine compartment is if you add a couple black nylon lines in the mess most people will never look.Oh what the hell you talked me into it. :twisted:
nova6511
Re: 1800*
Postby BC847 » Thu Aug 04, 2011 5:34 pm
Sneak an aftermarket cam in there thus dropping the EGTs more by allowing more air through the engine (and dropping the peak boost number). ;)
Re: 1800*
Postby nova6511 » Thu Aug 04, 2011 5:41 pm
Ive looked at cams,not found a hole lot on people doing cams to get any info on them.What to buy or size or anything.
nova6511
Re: 1800*
Postby Hansen01 » Fri Aug 05, 2011 4:37 pm
nova6511 wrote:I have thought about it.The one nise thing about a cluttered engine compartment is if you add a couple black nylon lines in the mess most people will never look.Oh what the hell you talked me into it. :twisted:
your welcome :D :D
Hansen01
Re: 1800*
Postby ahale2772 » Mon Aug 08, 2011 6:59 pm
raced a Durtymax on the highway today, pegged my pyro for a good 10 seconds :shock: ....took a picture afterwards, going like 90(speedo is way off)..3/4 throttle, racing up towards the 1500 degree mark like it was going to hit and bend the needle.
...but I beat the d-max 8) , at the light after the short highway run he said his pyro-limiter cut fuel at 117 :D :grin:
