new starter
new starter
Postby 91bluecummins » Wed Aug 03, 2011 7:10 pm
What is the tools that i need to replace my starter. What size is the enverted torque bolts. and the best way to get them out. thanks
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: new starter
Postby peobryant » Thu Aug 04, 2011 8:43 am
I just did this a few weeks ago. I can't recall of the top of my head but I want to say the bolts were 15mm. It's a really simple job and the only thing that I had any sort of trouble with was one bolt getting the starter back on. You'll know which one I'm talking about when you get to it. ;)
Re: new starter
Postby 1990 » Thu Aug 04, 2011 9:28 am
There 12 point heads. You'll need a 12 point socket. I believe mine where 12mm.
2012 Subaru WRX TP Stage 1 DD
Re: new starter
Postby peobryant » Thu Aug 04, 2011 3:38 pm
1990 wrote:There 12 point heads. You'll need a 12 point socket. I believe mine where 12mm.
Mine may have been as well. I was thinking 12 or 15, but I'll go out and have a look in a minute to make sure.
Re: new starter
Postby 91bluecummins » Thu Aug 04, 2011 6:37 pm
well i got it off and it sucked i had those inverted torque bolts that were 15E and one of them stripped so i got the old tourch out so then i put regular metric bolts back in it so it will be easier next time i haft to remove the starter
91bluecummins
Re: new starter
Postby peobryant » Thu Aug 04, 2011 8:31 pm
91bluecummins wrote:well i got it off and it sucked i had those inverted torque bolts that were 15E and one of them stripped so i got the old tourch out so then i put regular metric bolts back in it so it will be easier next time i haft to remove the starter
That shouldn't be for a long while. I've had my truck close to five years and I just had to change mine a few weeks ago.
