Made the 400HP Auto A518 club over the weekend
Postby SNOOT » Thu Aug 04, 2011 9:37 am
Its no 600 or 700HP but it is an automatic A518 non-lock up drag racing machine...
So-far this year I have improved my 1/4 mile ET from 14.23 last year to 13.55 this year. I ran on BD's dyno last month and made 376HP and on the same day ran the 13.55 1/4. Last weekend and one additional turn of the fuel screw I made 405HP.
I am still running the 12mm pump with AFC. Changes made this year... New injectors and a 4,000rpm gov spring.
Every run I made dyno and 1/4 mile run was under 1250 on the EGT meter.
Needless to say I am stoked at how well the truck is running around the street and on the road. The shifter is now all hooked up and I look forward to running the 1/4 mile on the 20th in Portland. Hoping for a low 13's.
1993 W350
SNOOT
Re: Made the 400HP Auto A518 club over the weekend
Postby ellis93 » Thu Aug 04, 2011 9:58 am
Very nice!
Postby dazedandconfused » Thu Aug 04, 2011 9:59 am
Cool.
Postby 1STGENFARMBOY » Thu Aug 04, 2011 8:50 pm
I don't know how you can keep from crankin that screw in and see what she has,
i think it could make an easy 450+hp and 13.00 is in site.
Dar
Postby SNOOT » Thu Aug 04, 2011 8:59 pm
1STGENFARMBOY wrote:I don't know how you can keep from crankin that screw in and see what she has,
Dar
I know I know....
1993 W350
SNOOT
Postby 1arock » Thu Aug 04, 2011 9:12 pm
Very impressive crank her down and let her eat just one time. I have never been one to show much restraint or smarts for that matter. Rocky
92W250 w/a 68D100 skin,tach, pyro, boost, trans temp guages, rebuilt a518 w/a PTC converter, 4in muffeled exhaust, 3200 gov spring, he351cw,M@H dynamic timing, 5x12s,M@H M3 pin, pump jacked with, 3.54s, 6+ lift, 14.5x36r rubber,nearly done,"What was I thinking?"
1arock
Postby soggy » Thu Aug 04, 2011 10:25 pm
Good job Snoot, one of these days we need to get together and make a side by side pass.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby bgilbert » Fri Aug 05, 2011 6:15 am
Congrats!
Bill Gilbert
Postby The_Head » Fri Aug 05, 2011 4:14 pm
dyno plot?
The_Head
Postby oldestof11 » Fri Aug 05, 2011 4:17 pm
1arock wrote:Very impressive crank her down and let her eat just one time. I have never been one to show much restraint or smarts for that matter. Rocky
You should see his donut vids. :shock: I am surprised he has restrained from cranking that puppy in!
Postby The_Head » Fri Aug 05, 2011 4:23 pm
I'm also interested in the torque it made.
The_Head
Postby SNOOT » Fri Aug 05, 2011 6:29 pm
The 405HP they did not hook up the crank trigger..
BD put me at 877TQ when I made 376HP..
#34 on the list... http://www.dieselperformance.com/index. ... dex/result
1993 W350
SNOOT
Postby SNOOT » Fri Aug 05, 2011 6:34 pm
http://youtu.be/Drh0AOjEOqw
1993 W350
SNOOT
Postby The_Head » Fri Aug 05, 2011 7:43 pm
SNOOT wrote:The 405HP they did not hook up the crank trigger..
The torque numbers are estimated on that list. They used 2250 rpm as a generic rpm input for calculating peak torque.
The_Head
Postby The_Head » Fri Aug 05, 2011 8:35 pm
Do you have any porting and polishing done on your head?
The_Head
