I know Rich doesn't want to do it, but I think he would benefit from a 1/8 timing bump. It's just a little, not a lot, and if he didn't drive it like he stole it he wouldn't have to worry about the head gasket. Yeah right!
ellis93 wrote:But that still means that fuel is injected sooner, right? This would mean more burn time on top of the piston, right? If so then the cylinder temps would have to increase to some degree. I would have to assume that the folks pushing the pump to the head have a lot to worry about.
PToombs wrote:The EGT's go down when you advance the timing because it's burning in the cylinder before the exhaust valve opens, not as the valve opens. In other words, it's not burning in the manifold and turbo because it's done burning when it gets that far. It does raise cylinder pressures though. I don't think it raises cylinder temps much, it can only burn so hot in there, and then the piston pushes it out.
