thinking turbo and injectors
Postby firstgennutty » Tue Aug 16, 2011 5:34 pm
lookin at turbos for my truck currently its just pump tuned with denny t
92 d250 single cab intercooled fuel pin turned up to correct idle (idle screw gone)
and stock piped
im looking at injectors as well was thinking somethin like pods but they may be too small for what i want to do
truck maybe some 5x.014?
looking at maybe a s400 but havent seen anyone run it alone?
http://www.citydiesel.net/b2-s400-turbo-p-84.html
truck would be a sunday driver, tow/drag a little (well maybe)
it would also see a 4" turbo back set up
firstgennutty
Re: thinking turbo and injectors
Postby AHineman » Tue Aug 16, 2011 6:00 pm
I run one of those under an s300g. BAD idea as a single. :lol:
If you want to run 5x.014s, try a 62/65/14.
Postby Kasper Cummins » Tue Aug 16, 2011 6:49 pm
6x.016 go big that way you don't need to buy them again. Just tune your pump down if you need to.
If I could do it again this is what I would do either 6x.016 or 6x.018
92 W250 club cab
Kasper Cummins
Postby Overdrive » Fri Sep 02, 2011 6:35 pm
Kasper Cummins wrote:6x.016 go big that way you don't need to buy them again. Just tune your pump down if you need to.
Where should one start looking for 6 x .016 injectors? Most places rate injectors with HP rating, but no specs. I'm also looking to do the turbo and injector trick, but probably an S300G single.
Overdrive
Postby AHineman » Fri Sep 02, 2011 6:40 pm
The S300G is not enough turbo to run as a single with 6x.016s and any pump tweaks.
Postby Kasper Cummins » Fri Sep 02, 2011 7:46 pm
I think 6x16 need to be custom made.
Richie O runs 6x16 with a HTT 62/71/14, so a S300 can be used you just need to tune your pump for them.
92 W250 club cab
Kasper Cummins
Postby AHineman » Fri Sep 02, 2011 7:56 pm
Kasper Cummins wrote:I think 6x16 need to be custom made.
An s300g is a 57/65/14 or 57/65/12. The 62/71/14 flows alot more. ;-)
Postby Kasper Cummins » Fri Sep 02, 2011 8:00 pm
An S300 can be as big as 64mm inducer so you can get an S300 62/71/14
92 W250 club cab
Kasper Cummins
Postby dazedandconfused » Fri Sep 02, 2011 8:02 pm
And his truck still doesn't have enough air and gets hot fast especially towing he said.
Postby AHineman » Fri Sep 02, 2011 8:02 pm
He said s300g. The s300g is a box stock Borg Warner turbo. You're talking about custom made turbos...
Looks like this.
Postby Kasper Cummins » Fri Sep 02, 2011 8:11 pm
Sorry, yes I was think of custom S300.
92 W250 club cab
Kasper Cummins
Postby Richie O » Fri Sep 02, 2011 8:40 pm
Well, glad I could help. :lol:
Postby Overdrive » Sat Sep 03, 2011 7:42 am
Oops, yeah, I meant some sort of S300 based turbo. I haven't bought any parts yet, so I'm not limited to anything specific. :)
Overdrive
