Coolertubz, who has them? What are your gains?
Re: Coolertubz, who has them? What are your gains?
Postby ellis93 » Fri Aug 19, 2011 7:33 pm
cumminz90 wrote:thanks i recomend them to anybody tim is a great guy to deal with for sure!!
I'll second this!
Tims great to deal with. He responded to my "ONE" E-mail with a phone call. If I get another 1stgen, I'll buy another set.
Postby cumminz90 » Fri Aug 19, 2011 7:45 pm
Tsbourne09 wrote:What are those breather looking things between your valve covers?
They are just cheap valve cover breathers i put in the valve covers. that was a bus motor that had ring sealing issues and had a lot i do mean a lot of blow by when it warmed up those helped make it not look so much like a wore out old farm truck :lol: its got a rebuilt motor now and it looks way better then it did (paint wise) in those pics even tho it still is on the stand :oops:
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Postby Tsbourne09 » Fri Aug 19, 2011 10:41 pm
I got mine powder coated candy blue with metalic! I got the new style seals from cummins and they are hella big and thick and grey! No leaks so far. Are the breathers worth it?
Not On Yet: 60#VS
Tsbourne09
Postby cumminz90 » Sat Aug 20, 2011 7:48 am
yea mine are powder coated candy red metallic and the turbo housings are now black metallic and the block is silver now but yes i would say the breathers are worth it ( they were in my application i have some bigger ones now after i bought the cheap ones just to try them out )
cumminz90
Postby Tsbourne09 » Sat Aug 20, 2011 4:25 pm
Ow nice! Got a current pic?
Not On Yet: 60#VS
Tsbourne09
Postby cumminz90 » Sat Aug 20, 2011 8:59 pm
This is how it looks as of this afternoon :D the first gen oil pan is powder coated red and the injector lines are too just a few little parts and things i need before they go on hope you like it!
cumminz90
Postby Tsbourne09 » Sun Aug 21, 2011 7:08 pm
Awsome! That looks great!
Not On Yet: 60#VS
Tsbourne09
