crewcab59 wrote:04fummins what trany did you use, if it is the dodge 727, or the a518 you should upgrade the torque converter, (don't know
what ford has) just thinking, if it is a manual it won't take much to get to 300hp.
oldestof11 wrote:Stock fuel pin ground on the deep side is the best for the money. Then you turn it around to the shallow side for economy.
The ZF6???? How do you like it?
