LOOOOONG box
both inside and out
LOOOOONG box
Postby TRENDZ » Mon Sep 19, 2011 7:16 pm
I've been dabbling with this truck for about a year now. I'm in the final stages of assembly. The truck is a early 91 that has had a basic overhaul, and more than a few custom things. Anyway, the truck is a 159'' wheelbase cab/chassis frame. I decided to lengthen the bed instead of shorting the frame or adding something in the 27+ inches of extra truck. Anyway, after much indecision over what to do, I ended up chopping up a real nice bed I found locally on c/l for a real deal of $400. The 27 inches of length added was all fabricated sheetmetal, so I didn't have to cut up two beds. Being a cab/chassis, the axle width is a bit to narrow for tire clearance inside the wheel well. I had to move the inner walls of the wheel houses inward. I still have 48 1/2" inches of floor between the wheel wells, so I can still get a 4'x8' (ooops I mean 4'x10' :lol: )sheet of drywall in there in one piece. The fender flares are made of part of the factory wheel openings and some fabbed sheetmetal. Not quite the factory look at all, but it was a good way to fill some missing space in the outer skin of the box. As goofy as it looks, I think the factory style fenders would have made the box appear even longer, and more accurate bodywork would have needed to be done on the bed side. The factory fenders also would have been to wide as the axle being 5 inches narrower. Anyway, I'll try to post a pic.
91 d350 1/2" supply lines, 2nd gen lift pump, regulator, 366, screwed, homebrewed afc pin, linkage mods, ported head, ported ex manifold, 351ve electrically controlled, 3" boost tubes, 2nd gen I/C, 4" ex, goerand
TRENDZ
Re: LOOOOONG box
Postby TRENDZ » Mon Sep 19, 2011 7:19 pm
Another...
TRENDZ
Re: LOOOOONG box
Postby TRENDZ » Mon Sep 19, 2011 7:20 pm
One more...
TRENDZ
Re: LOOOOONG box
Postby ellis93 » Mon Sep 19, 2011 7:46 pm
I like it ;-) I like the fenders as well.
Looks like bondo time.
Re: LOOOOONG box
Postby ahale2772 » Tue Sep 20, 2011 4:34 am
very cool, got that older ford/chevy dually fender look, good work
Re: LOOOOONG box
Postby diesel freak01 » Tue Sep 20, 2011 5:25 am
Very cool. Im digging the fenders! :grin:
1993 d350 ctd drw 2wd auto
diesel freak01
Re: LOOOOONG box
Postby PToombs » Tue Sep 20, 2011 5:56 pm
That'll look cool when you get it done. Don't forget us pic addicts!
Re: LOOOOONG box
Postby dazedandconfused » Tue Sep 20, 2011 6:01 pm
I like it.
Re: LOOOOONG box
Postby Tacoclaw » Tue Sep 20, 2011 6:05 pm
Sharp truck and impressive fab work!
Got any plans to make it turn sharper? I'd say you'll need it. :P
Re: LOOOOONG box
Postby Mark Nixon » Thu Sep 29, 2011 8:57 am
Nice work, not the look I would care for on the fenders, though, too "Ford-ish".
I do like the use of the old bedsides for the wheel radius and body line, which is a nice touch.
If you like it, that's all that matters.
Re: LOOOOONG box
Postby oldestof11 » Thu Sep 29, 2011 5:24 pm
Nice!!!!
Re: LOOOOONG box
Postby TRENDZ » Tue Oct 18, 2011 4:49 pm
Getting ready to bolt it on for good. Here's a few pics.
TRENDZ
Re: LOOOOONG box
Postby TRENDZ » Tue Oct 18, 2011 4:52 pm
more... Oh, I dont think I mentioned what the cut outs in the lower end are for. I'm making stainless steps/ fender bash gaurds. They will be connected to the frame to prevent the innevedable fender damage that is likely to occur.
TRENDZ
Re: LOOOOONG box
Postby dazedandconfused » Tue Oct 18, 2011 5:09 pm
Looks nice.
Re: LOOOOONG box
Postby collegekid » Tue Oct 18, 2011 9:28 pm
you do the paint yourself? if so, what was your setup on it?
collegekid
Return to Body
