HE351 and injectors
HE351 and injectors
Postby Haywagon » Mon Oct 31, 2011 7:39 pm
Hey guys getting my project rolling here and i just got my turbo , HE351cw now I'm looking for a set of injectors. I have looked around some but no deff answers. I was thinking some SDX 5x14 or some ddp 3or ddp 4 but was told sdx is a better built injector. Anybody running New era 435's are these too big its just a toy to bomb around in :D
1992 reg cab 4x4 getrag 165K
Intake
4" pipe
366 spring
33x12x18 mud grapplers on 18x10 KMC Spy
Haywagon
Re: HE351 and injectors
Postby Haywagon » Tue Nov 01, 2011 11:58 pm
No ideas i see one guy running PODS that my only option
Intake
4" pipe
366 spring
Haywagon
Postby ahale2772 » Wed Nov 02, 2011 4:04 am
pods will be smokey but cheep, they should support about 400hp, i would try ddp injectors, they burn pretty clean and should let you dial in that turbo without having a stupid smokey truck
Postby dvst8r » Wed Nov 02, 2011 7:54 am
I just sold a set of SDX 5x.014's to a customer who is running the HE351cw as a single, his only complaint is that it had too much power and broke the input shaft on the transmission. He has since built an 47RH and is now building twins for towing.
dvst8r
Postby oldestof11 » Wed Nov 02, 2011 1:15 pm
ahale2772 wrote:pods will be smokey but cheep, they should support about 400hp, i would try ddp injectors, they burn pretty clean and should let you dial in that turbo without having a stupid smokey truck
PODs are no longer cheap. For the awfulness of them, they were tolerated before. Now that you can get a nice set of 5x12's for around $600, or be like me and get a set on Non-IC'd injectors and turn them down, they are bad.
FWIW, I bought a set of Non-IC'd sticks and got them turned down for $25. For $125 all together, those are the CHEAPEST sticks you will find that get that can make some power.
Postby collegekid » Wed Nov 02, 2011 4:49 pm
so you would go with a set of non-ic'd sticks over the pods or 5x12's?
collegekid
Postby oldestof11 » Wed Nov 02, 2011 5:34 pm
Price wise? Yes.
Performance? 5x??.
PODs? Never unless they are sub $200.
My 2 cents worth.
Postby Haywagon » Thu Nov 03, 2011 6:41 pm
Thanks guys im leanin for sdx 5x14s , now looks like some knowladgeable guys on here what about a batmo wheel to the eqation ? Along with a nice intercooler i would think it would be a great combo any thoughts ?
Intake
4" pipe
366 spring
Haywagon
Postby rattlebox93 » Thu Dec 15, 2011 10:31 pm
Im running 6x16s with my 351 with a 4200 spring clipped a1000 boost ref reg set @ 25 lbs -6 all the way from the a1000 to the pump they are stupid smokey at an idle but have lettle more than a haze @ wot with sub 1900* temps but i have the head industrial man and ex housing hogged way out send me a text and ill send some pics 618 920 2827 i will never own a 1st gen without a ind man and 3rd gen type charger again not to mension there are tons of 3rd gen hi techs and such for sale cheap on comp d
rattlebox93
