Gonna do twins need advuce
Re: Gonna do twins need advuce
Postby Remps » Wed Nov 02, 2011 9:44 pm
I'd like to see how Stomp's truck would perform with a S475 instead of that ht3b. 600+ hp is proof enough that a twin setup with an ht3b can make big power, with a lot of supporting mods.
Postby elm302 » Thu Nov 03, 2011 6:54 am
What would be a good price for a used 3b also found a bht3c any good ?
93 W250 Getrag Valair clutch HIDS 3200 spring Denny 2 pin M&H spacer Airdog 150 5x16s 63/68/.91 4" duals Isspro gauges BHAF 2nd gen intake water meth 60# springs 3 piece manifold. Next up PS intercooler
elm302
Postby 1990 » Thu Nov 03, 2011 5:29 pm
elm302 wrote:What would be a good price for a used 3b also found a bht3c any good ?
http://www.citydiesel.net/bht3b-turbo-p ... Path=32_34
Don't know the history on the site though, seems like a good price.
2012 Subaru WRX TP Stage 1 DD
Postby Tacoclaw » Thu Nov 03, 2011 5:47 pm
I may be incorrect on this, bu apparently the Ht3s spin the wrong way from most turbos. If you set it up for a normal rotation from the start you may have a better set of options should you decide to upgrade.
If you had the HT3 laying around I would go ahead and use it, otherwise the S400s aren't really that expensive. A new S400 like I have is only $600...
If that's too much, you may want to reconsider twins. :lol: Those thing will nickle and dime...well, $10 and $50 you to death after you get started on them. ;-)
Postby elm302 » Thu Nov 03, 2011 6:30 pm
Not really that I cant afford a S400 Its more I like the ease of the 3b setup seems super easy to deal with. I seem to find alot more of the 3bs as well.
elm302
Postby oldestof11 » Thu Nov 03, 2011 6:44 pm
The problem with STOMPs setup is he is already clearing up all the fuel. He needs bigger sticks...
Postby elm302 » Fri Nov 04, 2011 6:03 pm
welp got me a 3b for 270 shipped hopefully gonna order the rest of my stuff next week.
elm302
Postby elm302 » Wed Nov 09, 2011 8:56 pm
Ordered studs and upper gasket kit today just got a std size headgasket.
elm302
Postby shiftycapone » Mon Nov 14, 2011 11:10 am
Remps wrote:S471 is good for 100 lbs/min, S475 110 lbs/min. Depends how you run your truck, where you want the powerband to be, and how much power you want to make. For comparison the super b special is 80 lbs/min (1160 cfm).
If you think a 71mm s400 will make an honest 100lbs/min, then your smokin crack. And that 64mm super b special doesn't flow 80lbs/min either.
HT3b is old school, yes. BUT, they work great and have made more power than most need. I ran one on my 24v under the hx35, and it ran great.
1990 D250
shiftycapone
Postby KTA » Mon Nov 14, 2011 2:24 pm
According to the maps a 71 flows about 80lbs/min and a 75 flows about 90lbs/min at boost and 70%eff.
Postby shiftycapone » Mon Nov 14, 2011 11:35 pm
KTA wrote:According to the maps a 71 flows about 80lbs/min and a 75 flows about 90lbs/min at boost and 70%eff.
Thank you, that sounds much more like reality.
1990 D250
shiftycapone
Postby elm302 » Tue Nov 15, 2011 6:08 am
Should I go with a std headgasket or a .10 over ?
elm302
