Calculating pressure - come on in math nerds
Re: Calculating pressure - come on in math nerds
Postby Tacoclaw » Mon Nov 07, 2011 6:54 pm
I spent the last few minutes looking up that clip where Ogre is yelling at the Nerds on that movie, then realized there's no embedding on this site. :lol:
Postby PJ 3 » Mon Nov 07, 2011 6:58 pm
PToombs wrote:Another thing I rember my ex-boss talking about was a Ram. It was a gravity water pump thinger. It was shaped like a hot air balloon, water ran into it, then when it was full, a valve opened and it dumped out, pushing water down the line. Pretty cool, an early, simple water pump that needed no power.
I have one of them at my camp. They are simple to make. I have plans to assemble one for cheap if anyone's interested. A few black iron fittings and a couple of brass check valves and your on your way !
Pete
1992 W250
PJ 3
Postby ellis93 » Mon Nov 07, 2011 8:15 pm
PJ 3 wrote:I have one of them at my camp. They are simple to make. I have plans to assemble one for cheap if anyone's interested. A few black iron fittings and a couple of brass check valves and your on your way !
Yes yes yes I would like to have them. I've a pond next,to a creek,I want to fill.
Postby PToombs » Tue Nov 08, 2011 5:53 pm
Pete, maybe start a new thread with the directions. I'm curious too as I can't remember exactly how it works.
Postby Richie O » Tue Nov 08, 2011 8:37 pm
PToombs wrote:Pete, maybe start a new thread with the directions. I'm curious too as I can't remember exactly how it works.
Remember PToombs, PJ3 is from Canada, and even their toilets spin backwards. :lol:
Postby meby » Wed Nov 09, 2011 5:01 pm
check out http://www.lehmans.com/. They still sell rams.
Pete, I hadn't really thought about using one. I do know that you don't need a lot of drop to make it work. Grandpa's house in PA used to have one that pumped water a 1/4 mile up and elevation of roughly 25 feet and it only had 3 foot of drop from the spring to the creek. I think the main thing with rams would be proper sizing: they work pretty slow.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby PToombs » Wed Nov 09, 2011 6:21 pm
Matt, lots of good info in there. I had to hunt a little, but it told the basics of how it works, how to adjust it, etc.
Postby PJ 3 » Wed Nov 09, 2011 6:25 pm
I guess I'm gonna have to find them and figure out how to get em posted eh ? Damm computer stuff............grrrrrrrrrr
Pete
1992 W250
PJ 3
Postby PToombs » Wed Nov 09, 2011 6:27 pm
Jeez, don't stroke out about it! :shock: It's not that important, I just thought others might like to know too.
What is it with guys named Pete? :roll:
Postby PJ 3 » Wed Nov 09, 2011 6:30 pm
:jumpsmile:
Pete
1992 W250
PJ 3
Postby PJ 3 » Wed Nov 09, 2011 6:57 pm
We have out houses up here......... 8)
Pete
1992 W250
PJ 3
Postby Richie O » Wed Nov 09, 2011 6:58 pm
Postby meby » Sat Nov 12, 2011 5:33 pm
On second thought, I don't think a ram would work in my situation because of the rams need to pump continuously. I don't have any creeks or springs to use.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby Douglas » Tue Dec 13, 2011 4:30 am
hey-Hey!!!,
The pressure drop in the pipe is due to flow friction. This friction head is equal to the height you've got the water level at. So pick the maximum or 20', that's about 10 psi... but the equations will deal in head height so it doesn't matter. account for all friction causing bits, and see what your flow will be. If it isn't enough, choose bigger pipe.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Postby KTA » Tue Dec 13, 2011 10:39 am
As long as you continue to have drop from your tank you will most likely still have flow. Your actual head will be the diffrence in elevation from your destination and the waters origin, not just the height of the tank. Also water is clingy. You can get it to flow further out of an open top pipe or trench than you can an enclosed pipe. Air offers little resistance so it allows the flow to continue even against wall friction.
