Load Range D Tires
Load Range D Tires
Postby 1990 » Tue Nov 08, 2011 5:22 am
My D250 had load range D tires on it. Now that's i've put the 4WD axle underneath it, i've noticed they look like they can't handle the extra weight?
Lately the the tires will flat spot after sitting for one night and even during work.
2012 Subaru WRX TP Stage 1 DD
Re: Load Range D Tires
Postby BILTIT » Tue Nov 08, 2011 6:45 am
How much pressure in them?
Derek B.
BILTIT
Postby 1990 » Tue Nov 08, 2011 7:24 am
55 PSI
60 PSI is max a believe.
Postby Subliminal » Tue Nov 08, 2011 8:43 am
My tires are D's. BFG All-Terrain 33x12.5. Work just fine...and I've filled the bed with mulch more than a few times. :)
Subliminal
Postby ahale2772 » Tue Nov 08, 2011 9:50 am
I thoght BF a/t's are E?
im pretty sure mine were..
Postby Subliminal » Tue Nov 08, 2011 10:00 am
Maybe it's because of the 16.5 inch wheels. I dunno...definitely Load Range D. My dad calls them 'maypops'. ;)
Subliminal
Postby ahale2772 » Tue Nov 08, 2011 10:11 am
mine we 16.5 as well I dono i may be wrong. I loaded the crap out of mine... no doubt about that
Postby BILTIT » Tue Nov 08, 2011 11:26 am
33x12.5 BFG AT's on 16.5 rim are "D" range.
Derek B.
BILTIT
Postby Richie O » Tue Nov 08, 2011 3:03 pm
BILTIT wrote:33x12.5 BFG AT's on 16.5 rim are "D" range.
Mine are as well.
Postby ahale2772 » Wed Nov 09, 2011 5:10 am
welp Guess i was wrong, always called them E's, always loaded them like E's :oops:
Postby Hansen01 » Wed Nov 09, 2011 6:15 am
i have a completely different brand of tires that are D's ive had a gooseneck full of bales sit on them on night and still no flat spots
Under construction...
Hansen01
Postby 1STGENFARMBOY » Fri Nov 11, 2011 1:19 pm
I just traided tires with my daughter, her's were Dayton Temberline 285-75-16's load (D) with a max of 3305 lbs with 65 psi.
The ones i gave her were Yokahoma Geolander 235-85-16 load (E) with a max load of 3100 at 85 psi.
don't know what's up with that but i like the Daytons better.....to bad there discontinued.
