Fnschlaud4620 wrote: I am not saying the shop you picked doesn't know what there are doing. But if they did, shouldn't they know which head gasket to use?
DTanklage wrote:you have 2 heads
one block
see where i am going with this?
ps - the machine shop around the corner charges 20 bucks a hole to o-ring. he does excellent work and i use him a lot (boring, decking, o-rings, hot honing with torque plate, etc) i dont understand 300-$350 to o-ring 6 cyl engine
DTanklage wrote:if you really want to send your head there i can get the info but arent you gonna spend more on frieght than you save?
roxxx wrote:
...Even more so in the diesel
roxxx wrote:In past with gassers i had to provide head gaskets to make sure compression was right if not and they might mill to much of head or deck the compression goes up, and valve clearance is compromised. Even more so in the diesel
