Let me ask it a different way
Re: Let me ask it a different way
Postby Mark Nixon » Fri Nov 25, 2011 8:37 pm
Shoot a large stream into a wide bowl, it's likely better than a thin stream into a narrower one and would likely burn clean and make more power, with an appropriate turbo.
The orientation of the injector, in relation to the bowl, on a 12 valve is subject to potential pressure disturbance.
Not to compare apples and oranges, but a VP motor makes good power and runs cleaner due to the more direct shot at the bowl.
Postby skilletky » Sat Nov 26, 2011 7:51 am
what is the best type of nozzle to use VCO, SAC, ect? can it make that big of a difference?
skilletky
Postby JQmile » Sat Nov 26, 2011 3:18 pm
My 5x25's are cleaner than the 6x16s, until I nail it. Here is light throttle in 3rd gear locked up a hill with 3.07s in my 89...no haze.
http://www.youtube.com/watch?v=j_LRovijq7E
In my experience mpg and driveability is still 90% right foot :D
JQmile
Postby skilletky » Sat Nov 26, 2011 4:45 pm
They obviously make more power than you 6x16's. Who made them jq? How are they egt wise?
skilletky
Postby dazedandconfused » Sat Nov 26, 2011 5:20 pm
skilletky wrote:They obviously make more power than you 6x16's. Who made them jq? How are they egt wise?
Chris I'm almost posotive scheid built them. Time to put that other charger on there.
Postby skilletky » Sat Nov 26, 2011 5:47 pm
if i would have read his sig i would have known, lol.
skilletky
Postby delinquent » Sat Nov 26, 2011 5:51 pm
I would place a small wager says a 4 hole would make more power in his truck with the bottle...
delinquent
Postby cougar » Sun Nov 27, 2011 9:29 am
JQmile wrote:My 5x25's are cleaner than the 6x16s, until I nail it. Here is light throttle in 3rd gear locked up a hill with 3.07s in my 89...no haze.
OK, try it again with a 7,000lb trailer behind you and report back your egt. :mrgreen:
01 2500 "the work truck".
cougar
Postby oldestof11 » Sun Nov 27, 2011 12:39 pm
delinquent wrote:I would place a small wager says a 4 hole would make more power in his truck with the bottle...
But too big of a hole with too much boost is a good way to air lock the injector. Also too big of holes can create weak points between the other holes.
Postby Tacoclaw » Mon Dec 19, 2011 6:13 pm
Just found this quote from Mr. Smokem himself referencing 12vs, it may clear some things up on your selection.
Smokem wrote:We use the 7-hole injector at times, but only in stock form. If you are looking to make power, go with a 5-hole nozzle.
Postby oldestof11 » Mon Dec 19, 2011 6:30 pm
Did you see him recommend a 7 hole for VE's though? He said something of the fact that at higher RPM's the 5 holes shine but in the lower RPM's that the VE and VP like to make their power the 7 holes are best. :?
Postby Tacoclaw » Mon Dec 19, 2011 6:53 pm
Yup, 7 holes with the wide spray angle. Pretty easy for us non-IC'd guys, but it would require different pistons for the later trucks with their baby bowls.
