so i have 5x16's and a 63/68/.91 turbo and want to max the pump out. i can find post that give you the basics but then some pump mods overlap other pump mods? so if i wanted to completely max out this pump for speed and hp what all needs to be done? here is a list of everything i can find to do to the pump but dont know what is needed and what is not needed. this truck is a dd also. (but only about 30miles a day)
Longer smoke screw
power screw
AFC delete
remove spring above fuel pin?
star wheel
adjust low idle screw
remove full throttle screw
ground fuel pin
install 3200 spring
also last time i had the pump apart my starwheel was stuck? got about a 1/4 turn on it and it wouldnd move up or down anymore?
so if im looking for max power is it better to remove the afc or is it better to tune the afc? also i found some of these mods but dont know if they benefit anything so give me some feedback on what is worthless if any? or any other mods needed to be done? thanks for the help.
